So the shifter in my VR4 was getting difficult to move left and right before I parked it last year. I'm getting ready to get it back on the road again and wanted to sort out the shifter. The front to back motion of the shifter works just fine, but side to side is really stiff, so stiff that the spring on the shifter can't help place the shifter in the right spot.
I took the cable loose at both ends and if moves freely, as does the shifter, so the issue is not the shift lever that is in charge of actually engaging the gears I guess. Does this part ever need maintenance or lube? Or could this be a sign of an internal tranny issue? Can needing new transmission gear oil cause something like this?
