This is my 1990 Toyota 4runner with the pos 3.0 v6 engine.
It is fully equipped to handle the most demanding terrain , mostly the Icelandic artic and glacers.
*it is fitted with 44"x15"x18.50 Dick Cepek tires on 15" x 18" wide wheels
*and also equipped with a steering shock and a steering jack to help with the strain with those tires.
*Lower gear ratios of 5.71 with welded front diff and ARB locker in rear
*3 auxiliary fuel tanks ( 75gallons )
*The body is only lifted 3" .
*The fenders are cut to make the wheels fit and fender flares added.
*Brake hoses made longer and axle breathing moved higher.
* air pump and 10 gallon air converter, used to pump air in the tires after the air pressure in them has been droped down to 1psi for better float on top of
snow
* Engine adders are - aftermarked headers w. 3" open exhaust , and a K&N air filter.
*equipped with a Garmin GPS 182 software.
two ways of communicating is CB radio and the tait VHF.
* working lights on the sides, extra electrical system , 2 large 120 W Hella lights in front , High-lift jack , Two roof racks
