A ratcheting breaker bar can be one of your best friends...
2013 NG: 1st place, FWD Drags
91 AWD TT
Brute force is awesome. Had a seized rear toe bolt on the VR-4... The guy at the alignment shop broke his fancy-pants snap-on box wrench in half. I took it home and brute forced it with the two wrenches trick.Brute force also cost me a few hours on a turbo pull because I broke off turbo bolts...
No, I need a pair of gloves but it's been hard finding a pair that fit the way I want. I guess I just need to stop being so picky.
If I could use my foot and legs to break everything loose I wouldn't have no problems. LOL
I have a Bosh 1/2 inch impact driver but sometimes you can't get that baby in where you need it either. The other night I couldn't use it because the frane was bent towards the bold head and I couldn't get the socket on.
Of course you can..you are the Green-Lantern.
I really don't want to break bones either. OUCH!
I'm still learning about what tools to use when but I'm getting it quickly. Work smarter not harder!
That's my problem with the gloves. I want to be fingering everything while I'm working on it. I will have to make an effort to put them on when I need to.
We have one at the shop but it dosen't ratchet...Christmas list!
Hubby isn't around to help out here and I don't want to keep getting DJ to help me because then he has to stop working on what he's doing. It kind of defeats the purpose of me helping out.
Must resist temptation .. must resist ......
Seriously .. I decided long ago, if you need the tool, get it.
Sure, I have some I'll only use once in a blue moon, and thankful it was in the tool box to find.
But once I got it .. so much more better
Breaker bars are my best friend at times
That, and an impact driver
I hate stripped, broken or rounded fasteners.
They so badly slow your progress
If its stuck, lube it with 50/50 acetone & brake fluid
Take a breath, lube it again & will it off
This thread could digress quickly. First Granny is talking about fingering, now EZ is talking about lube.![]()
