Results 21 to 30 of 37
Thread: What (motor) did I end up with?
    Hmmm ok.
    replace the bearings, check the engine, then throw it in the SL or Base (whatever that is in your country)
    1996 GTO, Owner since 2003.
    I’d just drop it in one of those rolling chassis then. 3.5 can be pretty fun in a FWD.
    don't know about that...that sump is identical to the Montero sump...aka no cut out for the transfercase?
    Same as a Debonair sump mate. They only came in FWD.
  4. #24
    Is* pretty fun
  5. #25
    I was under the impression the debonair came with the cut for the transfercase or something?
  6. #26
    Incorrect good sir. They were a FWD only model, thus, no transfercase. You will find this is the case anywhere. Even on john monnins website. Even with a debonair sump it needs to be modified to clear the transfercase
    Just realized I used the words "Even" and "Case" way too much in this post.
  7. #27
    Now fwd TT = very fun
    truth
  8. #28
    Apr 2011
    Mid-April 2011.
    Monroe WI
    I hate you. I would love to go pu
  9. #29
    Sooooo, whats the point of going a debonair engine over a montero then....
  10. #30
    It's a direct drop in...(as discussed in many other threads) i.e. it's in FWD layout. Basically EXACTLY the same as a 3000GT engine. The montero one will need the 3000GT heads and god knows what else to work. The debonair one just goes *plop* straight into a 3/S/Magna :P
