So, here is the big question.
What do you do for a living?
I am the CIO and I run a little side computer business.
David P. - Savannah, GA
2009 BMW Z4 35i :: Mods :: Vishnu Performance PROcede ECU
2009 Mercedes ML-550 :: Mods :: None but fully loaded with ever option
1993 3000GT VR4 :: Mods :: Forged Block, APR Studs all around, Stage 3 Heads, Racing Cams, Adjustable Cam gears, TD05 Custom Billet 16G Turbos from DR, Custom Pre Turbo Pipes, 38x14x4 FMIC, 3inch custom intake, FUELAB Prodigy Fuel Pump and 2x filters inline @ -10AN, Fuellab Fuel Pressure Regulator with oohnooo hard lines, 1000cc Injectors, Custom Exhaust, Tial BOV, AEM EMS, AEM gauges (Fuel & Oil Pressure, A/F, Water Temp, Boost, & 2x Serial), 2x AEM A/F Sensors, 2x AEM EGT Sensors, Fidanza Aluminum Flywheel, SPEC Stage 5 Clutch, Steel front and mid transfer case upgrade, 2 Piece Aluminum Drive Shaft, Transfer Case Bracket, Quaife Front Differential, Kaaz Rear Differential, Super Car Engineering Center Differential, NOS Kit, 220 AMP Alternator, HKS Ignition Booster, All sensors replaced, EGR block off, Solid engine mounts, Tein FLEX Coilover, Ground wire kit, Iridium IX @ .028, if it's metal its polished or powder coated, and some other stuff.
FOR SALE 1994 3000GT SL :: Mods :: New 4 Bolt TT Engine, Stage 3 heads, Full turbo conversion (99 ECU), 6 Speed MR Transmission, 720cc Denso Injectors, 15G Turbos, 99 Flash ECU, 3.5 GM MAF With Translator, 36x12x3 FMIC, MR 6 Speed Transmission with Quaife Front Differential, Greddy Type-RS BOV, 3inch custom intake, Walbro fuel pump (hot wired), Tein FLEX Coilover, and other stuff.
“A turbo: exhaust gasses go into the turbocharger and spin it, witchcraft happens and you go faster.”
Sounds awesome.
If you need an employee and are paying more than I am currently getting paid, I am always here![]()
To be honest I don't remember, it's been a few months. I do have the full price below:Also, how much did that steering wheel run you?
2" Tuning 4-pt Snap-In Harnesses (2) - BLUE [04604BMAZ]
Steering Wheel Ring (1) - BLUE [01599AZ]
Hub Adapter Kit (1) - 1993 3000GT [01502106]
Lap 5 Steering Wheel (1) - ALL BLACK [015TL522TUV]
Dual Horn Button (1) [015NE982]
Total: $601.00 ShippedLOL your not the only one looking for a job or a better oneIf you need an employee and are paying more than I am currently getting paid, I am always here
Week end update:
This week end we got mike's single turbo up and running, though we still have allot to do before it hits the road. Also made some changes to my VR4's tuning. (That is the excitement for the weekend.)
Hey brother the build looks awesome. Subscribing to the thread.
Bump!!
-jeff
1992 SVX LS-L
1996 3000GT FWD-TT
2005 XC90 T6 AWD
i collect parts.
Well here is the quick update:
Car went to 3sx for tuning, but after a few hours of cruse tuning and then on the second pull at 14.4psi the new mechman alternator gave out blowing party of cylinder 6 out. It came back to the garage here that weekend and had everything rebuilt.
I also spent 23 days in Japan so I was gone most of April and the fabricating guy is now working on a custom body work; top secret work at the moment
On returning I am now finishing the transmission exchange on the 94 Auto SL and putting in a 6 speed AWD transmission with LSD and stage 2+ clutch. The factor auto made it to just over 181K miles before it just started to slip; it would have to do it right on return from vacation.
I will update one the body works done, painted, and gets it's full tune on the dyno; also when the SL gets it's new 6 speed put in.
Do a thread this Christmas on the lights!
