The wiring harness seems intimidating.
Engine harness is now complete:
Still to do:
Put brake kit on
Finish installing last wires inside the car
Put dash and seats in
Build custom HUD
Install second screen
Mount new inter cooler
Mount new bumper
Mount fenders
Build bulk head
Complete fiber glass interior items
Paint the car
David P. - Savannah, GA
2009 BMW Z4 35i :: Mods :: Vishnu Performance PROcede ECU
2009 Mercedes ML-550 :: Mods :: None but fully loaded with ever option
1993 3000GT VR4 :: Mods :: Forged Block, APR Studs all around, Stage 3 Heads, Racing Cams, Adjustable Cam gears, TD05 Custom Billet 16G Turbos from DR, Custom Pre Turbo Pipes, 38x14x4 FMIC, 3inch custom intake, FUELAB Prodigy Fuel Pump and 2x filters inline @ -10AN, Fuellab Fuel Pressure Regulator with oohnooo hard lines, 1000cc Injectors, Custom Exhaust, Tial BOV, AEM EMS, AEM gauges (Fuel & Oil Pressure, A/F, Water Temp, Boost, & 2x Serial), 2x AEM A/F Sensors, 2x AEM EGT Sensors, Fidanza Aluminum Flywheel, SPEC Stage 5 Clutch, Steel front and mid transfer case upgrade, 2 Piece Aluminum Drive Shaft, Transfer Case Bracket, Quaife Front Differential, Kaaz Rear Differential, Super Car Engineering Center Differential, NOS Kit, 220 AMP Alternator, HKS Ignition Booster, All sensors replaced, EGR block off, Solid engine mounts, Tein FLEX Coilover, Ground wire kit, Iridium IX @ .028, if it's metal its polished or powder coated, and some other stuff.
FOR SALE 1994 3000GT SL :: Mods :: New 4 Bolt TT Engine, Stage 3 heads, Full turbo conversion (99 ECU), 6 Speed MR Transmission, 720cc Denso Injectors, 15G Turbos, 99 Flash ECU, 3.5 GM MAF With Translator, 36x12x3 FMIC, MR 6 Speed Transmission with Quaife Front Differential, Greddy Type-RS BOV, 3inch custom intake, Walbro fuel pump (hot wired), Tein FLEX Coilover, and other stuff.
“A turbo: exhaust gasses go into the turbocharger and spin it, witchcraft happens and you go faster.”
Looking good Dave. Ill be over next week to take a look, Shouldn't you be at work right now? not working on your car...
Fully Forged, 16G's ect.
So over the week end I got some stuff done, but rain and going down to the local game store to play Warhammer made the week end progress a little slow.
Chris I was at workI just was updating my thread, you know keeping everyone in the loop.
What got completed:
Installed new inter-cooler, piping, sensors, and BOV
Finished wiring inside the car (minus the 4 wires left for the car PC and Amps)
Installed new Sail Panels
Put new seats and harnesses in the car
Installed new front brakes (still need to do the rear)
-= Some Pictures =-
Brakes:
Seat installed:
Sail installed:
I love those K-Sports man, be sure to let us know how they perform. Are going to go all the way around with them, or just fronts?
Fronts for now, I am replacing the rears with matching brake rotors and high end pads. I am also going to paint them the same orange color to match the front; give it the uniformed look all the way around. If I still want more then I will replace the back ones.
Be sure to do a detailed product review of the K-sports.
You are 1 of the 1st I have seen running them and a good detailed review would be great.
Will do; I was hesitate to go with K-Sport because no one else on the forms has them (all stoptech), but I figured I would go that way since I got them on a special deal (a price that was hard to beat and I can't repeat.) Also for reference these are the K-Sport 8 Piston 14" (356mm).
