Seriously, you couldn't find blue spark plug wires? jk, everything looks amazing. Very clean, nice work!
96 vr4
15Gs, FMIC, hotwired walboro, 560ccs, K&N, Greddy Type-S, SAFC, MBC, meth injection, 3sx lightweight pulley, strut bars, running open gutted precats (screw the polar bears, open ATR downpipe wasn't loud enough to piss off my neighbors at idle)
I'm looking for a FMIC kit, if you are selling one, PM me.
So my new update for the day is the following:
AEM EMS Series 2
AEM Boost Solenoid (30-2400)
AEM Digital Gauge - Boost Display Gauge 50psi peak (40-4408)
AEM IAT Intake Air Temp Sensor
So I decided to go with the AEM EMS for the VR4 and move the E-mange to the SL. It made money since over all... So soon I plan to make a road trip to 3SX to pickup all my new toys and say hello to the boys up there.
David P. - Savannah, GA
2009 BMW Z4 35i :: Mods :: Vishnu Performance PROcede ECU
2009 Mercedes ML-550 :: Mods :: None but fully loaded with ever option
1993 3000GT VR4 :: Mods :: Forged Block, APR Studs all around, Stage 3 Heads, Racing Cams, Adjustable Cam gears, TD05 Custom Billet 16G Turbos from DR, Custom Pre Turbo Pipes, 38x14x4 FMIC, 3inch custom intake, FUELAB Prodigy Fuel Pump and 2x filters inline @ -10AN, Fuellab Fuel Pressure Regulator with oohnooo hard lines, 1000cc Injectors, Custom Exhaust, Tial BOV, AEM EMS, AEM gauges (Fuel & Oil Pressure, A/F, Water Temp, Boost, & 2x Serial), 2x AEM A/F Sensors, 2x AEM EGT Sensors, Fidanza Aluminum Flywheel, SPEC Stage 5 Clutch, Steel front and mid transfer case upgrade, 2 Piece Aluminum Drive Shaft, Transfer Case Bracket, Quaife Front Differential, Kaaz Rear Differential, Super Car Engineering Center Differential, NOS Kit, 220 AMP Alternator, HKS Ignition Booster, All sensors replaced, EGR block off, Solid engine mounts, Tein FLEX Coilover, Ground wire kit, Iridium IX @ .028, if it's metal its polished or powder coated, and some other stuff.
FOR SALE 1994 3000GT SL :: Mods :: New 4 Bolt TT Engine, Stage 3 heads, Full turbo conversion (99 ECU), 6 Speed MR Transmission, 720cc Denso Injectors, 15G Turbos, 99 Flash ECU, 3.5 GM MAF With Translator, 36x12x3 FMIC, MR 6 Speed Transmission with Quaife Front Differential, Greddy Type-RS BOV, 3inch custom intake, Walbro fuel pump (hot wired), Tein FLEX Coilover, and other stuff.
“A turbo: exhaust gasses go into the turbocharger and spin it, witchcraft happens and you go faster.”
i like it! thats some coin and dedication there, keep up the good work man![]()
Looks Awesome! Real nice
Like where you got the power and distribution blocks. How is it all routed? Never realized there was that much room under the fender.
Well it runs from the back in the wire well on the passenger side. Then it comes out the wiring hole on the side behind the rear part of the fender (as pictured.) I cross the top of the wheel well behind the plastic cover and down around the new location of the fuse box (pictured) and finally to the distribution blocks (the blocks also run 0 gauge wires to the alternator as well.) The real trick is extending all the wires to move the fuse box, that's a time consuming project. The other piece I have to still put under the fuse box is the power steering cooler; I have an Earls cooler for that. There is plenty of space even with the ABS (soon to be removed) for the fuse box. Getting the cooler in there will take the last bit of space up; making the bottom of the cooler close to the bottom of the bumper.
I know other people have moved the fuse box inside, but I got enough other stuff inside that I did not want to clutter it up any more. The only bitch part is if I blow a fuse, then it takes a bit of work to get to the box. Really though how often do you blow one of these fuses if you did everything correctly.
is this the car that just put a tdo5 on the front and left the tdo4 on the back? If I am right he got a good bit of flack for it on 3si, glad to see its turned out this nice.
Coop
It is the same; I will say when it was like that it was a blast to drive. I won't get into my work around for it now, but it's do able with a little thought. I never listen to people BS any ways, to each there own![]()
New updates 11-6-2010:
Installed AEM EMS
Installed Hood
Install Fuel Cell
Moved battery
Installed secondary feeder pumps
Installed Boost Gauge
Still to do:
Install Boost control valve
Install Bumper
Install new bigger FMIC
Install & weld new Aluminum piping
Install new Tial BOV
Tune AEM EMS
Some Pics:
Just moving slow through this since I am working on my Christmas show; 150,000+ lights don't put them self up....
So here is my new update:
Completed:
New pipes welded
ABS Delete
Everything in pieces right now
New Parts to Install:
DR TD05 Billet 16G's
2x Tail 38mm Waste gates (remove knock off ones)
2x AEM Serial Gauges
2x AEM EGT sensors
AEM WiFi Adapter
3sx Duel Pass Radiator
New Car PC with duel touch screens
Front and rear wide body kit
2x new Sparco Seats (moving the one to the SL)
Rear bulkhead being built
NOS Kit install
Roll cage install
Install Canon plug between motor wires and ecu for fast removal
Free Mods:
All Extra wires deleted from the car
Rear Seats removed
To Buy still:
Stop Tech BB Kit
Old Turbo VS New Turbo:
and where do you think you're gonna put that spare wheel?!?!![]()
