You gotta tuck that exhaust up into the bumper at least... That should make it look a lot better.
Look awesome. I'd prefer a 2nd gen side skirt. But still sexy. And I agree with the rest on the exhaust It needs to be tucked! Congrats on a getting it done, the paint looks fantastic.
Other than exhaust, quality of your work looks amazing. Good job. Gotta ask, why the roof scoop??
Liked the look and made it unique. Always like to have the one off design then the run of the mill. Trust me if I could have tucked the pipes back I would have, but the mufflers are quite big. When I redo the system I will find some shorter one for certain.
David P. - Savannah, GA
2009 BMW Z4 35i :: Mods :: Vishnu Performance PROcede ECU
2009 Mercedes ML-550 :: Mods :: None but fully loaded with ever option
1993 3000GT VR4 :: Mods :: Forged Block, APR Studs all around, Stage 3 Heads, Racing Cams, Adjustable Cam gears, TD05 Custom Billet 16G Turbos from DR, Custom Pre Turbo Pipes, 38x14x4 FMIC, 3inch custom intake, FUELAB Prodigy Fuel Pump and 2x filters inline @ -10AN, Fuellab Fuel Pressure Regulator with oohnooo hard lines, 1000cc Injectors, Custom Exhaust, Tial BOV, AEM EMS, AEM gauges (Fuel & Oil Pressure, A/F, Water Temp, Boost, & 2x Serial), 2x AEM A/F Sensors, 2x AEM EGT Sensors, Fidanza Aluminum Flywheel, SPEC Stage 5 Clutch, Steel front and mid transfer case upgrade, 2 Piece Aluminum Drive Shaft, Transfer Case Bracket, Quaife Front Differential, Kaaz Rear Differential, Super Car Engineering Center Differential, NOS Kit, 220 AMP Alternator, HKS Ignition Booster, All sensors replaced, EGR block off, Solid engine mounts, Tein FLEX Coilover, Ground wire kit, Iridium IX @ .028, if it's metal its polished or powder coated, and some other stuff.
FOR SALE 1994 3000GT SL :: Mods :: New 4 Bolt TT Engine, Stage 3 heads, Full turbo conversion (99 ECU), 6 Speed MR Transmission, 720cc Denso Injectors, 15G Turbos, 99 Flash ECU, 3.5 GM MAF With Translator, 36x12x3 FMIC, MR 6 Speed Transmission with Quaife Front Differential, Greddy Type-RS BOV, 3inch custom intake, Walbro fuel pump (hot wired), Tein FLEX Coilover, and other stuff.
“A turbo: exhaust gasses go into the turbocharger and spin it, witchcraft happens and you go faster.”
Lookin good manLoving those fenders...
