No all 4 are custom; at one point I owned the cianci but sold it to my friend Mike when I went full custom. These are full metal ones.
David P. - Savannah, GA
2009 BMW Z4 35i :: Mods :: Vishnu Performance PROcede ECU
2009 Mercedes ML-550 :: Mods :: None but fully loaded with ever option
1993 3000GT VR4 :: Mods :: Forged Block, APR Studs all around, Stage 3 Heads, Racing Cams, Adjustable Cam gears, TD05 Custom Billet 16G Turbos from DR, Custom Pre Turbo Pipes, 38x14x4 FMIC, 3inch custom intake, FUELAB Prodigy Fuel Pump and 2x filters inline @ -10AN, Fuellab Fuel Pressure Regulator with oohnooo hard lines, 1000cc Injectors, Custom Exhaust, Tial BOV, AEM EMS, AEM gauges (Fuel & Oil Pressure, A/F, Water Temp, Boost, & 2x Serial), 2x AEM A/F Sensors, 2x AEM EGT Sensors, Fidanza Aluminum Flywheel, SPEC Stage 5 Clutch, Steel front and mid transfer case upgrade, 2 Piece Aluminum Drive Shaft, Transfer Case Bracket, Quaife Front Differential, Kaaz Rear Differential, Super Car Engineering Center Differential, NOS Kit, 220 AMP Alternator, HKS Ignition Booster, All sensors replaced, EGR block off, Solid engine mounts, Tein FLEX Coilover, Ground wire kit, Iridium IX @ .028, if it's metal its polished or powder coated, and some other stuff.
FOR SALE 1994 3000GT SL :: Mods :: New 4 Bolt TT Engine, Stage 3 heads, Full turbo conversion (99 ECU), 6 Speed MR Transmission, 720cc Denso Injectors, 15G Turbos, 99 Flash ECU, 3.5 GM MAF With Translator, 36x12x3 FMIC, MR 6 Speed Transmission with Quaife Front Differential, Greddy Type-RS BOV, 3inch custom intake, Walbro fuel pump (hot wired), Tein FLEX Coilover, and other stuff.
“A turbo: exhaust gasses go into the turbocharger and spin it, witchcraft happens and you go faster.”
From 9/21/2013
Cage Pictures
Update
So the last year has been cray and interesting:
- Went to China and Japan with my mom for a month in April 2013
- Went to Italy 2013 and asked my lady to marry me in July 2013 (Good times)
- Planing a wedding that will take place in the French Rivera
- Rebuilding Brian's car
- Starting the Christmas light's
- Selling my 94 SL turbo conversion
The car is starting it's second round of primer and should be painted in the next 2-3 weeks, so expect a big update then. Been a year and half coming, but it looks so good.
Congrads on getting engagement. Best of luck to you both.
Xmas lights in September? This I have to see.![]()
"Life should NOT be a journey to the grave with the intention of arriving in an attractive and well preserved body, but rather to skid in sideways, chocolate in one hand, martini in the other, body thoroughly used up, totally worn out and screaming "WOO HOO what a ride!"
----------------[2007 Ride of the Year.................................. 3.5 Stroker I did.w/DBB DR1000's
I have to start repair of the lights and begin putting out November 1st.
An example of what I did in 2011:
Yay your doing your lights again this year! Can't wait to see them. Cars looking good too. I'll stop by eventually
Fully Forged, 16G's ect.
you have a lot of money... haha im jealous!
Sorry for the late update, the care came back about 3 weeks ago, but have been super busy with the holidays, then before that got engaged in Italy, planning our wedding in London, working on B's car (doing a full ground up build), and Christmas lights. As soon as I get the lights down I will role the car out and take a little photo shoot.
But until then here are my Christmas Lights for entertainment:
Did you yourself or a local person build your cage?
Do you recommend having the dash in before the cage going in or leaving it out?
