Page 1 of 8 123 ... LastLast
Results 1 to 10 of 78
Thread: Cayenne/touareg/q7 BBK upgrade (product idea)
    brake caliper adapters for the Z18 (v10 touareg/cayenne turbo/Q7 ) front brembo 6 piston calipers that use 350mmx34mm rotors stock.
    Porsche parts number 2003 - 2008 Porsche Cayenne turbo Z18 caliper use with 350-380 x 3x mm rotors
    955-351-421-22
    955-351-422-22
    most common upgrade for the audi a4 b5 s rs.., porsches and for many VW concern cars,BMW's and japs too ...
    cayenne Z18 brake upgrade B7 RS4
    cayenne Z18 brake upgrade FD RX 7
    374 x 34 mm front rotors Z18 brake upgrade BMW 335
    345 x 28 mm rear rotors Z18 brake upgrade BMW 335
    Cayenne/touareg/Q7 Z18 calipers typically sell for $500-$800 for the pair online but if your lucky you can find them for even less than 500$
    These calipers should work with any 350-380 x 3xmm rotors with the brake caliper adapters . this caliper is a common upgrade for the Porsche 930 turbo from 1981-1989 and they use 355 x 34 mm rotors
    930 turbo brake Z18 cayenne turbo front caliper adapters
    930 turbo cayenne Z18 front calipers fitter
    I think evo x brake rotors would be a good choice, the price is very affordable and parts are very easy to source.
    Floating rotors vs solids the choice is yours
    http://www.lancershop.com/customer/p...cat=123&page=1
    http://www.amsperformance.com/cart/g...ors-front.html
    http://www.hopupracing.com/brfrcrropani1.html
    or you can buy used rotors for very cheap
    this is from 3si
    Quote Originally Posted by paul_666
    the evo x 350mm discs go straight on and are (from memory) 1.7mm closer to the hub !
    the 330mm rears on the EVO X will bolt up, but they do not have the same handbrake as the 3000GT
    I think paul_666 remembers wrong evo x rotors are actually 1,3mm or so outer but that is only a positive thing IMO, more room for the adapters. the cayenne front calipers are much slimmer than our stockers so wheel fitment shouldn't be an issue.
    rotor specs
    EVO X__________________2g 3000GT
    Diameter : 350___________314
    Width : 32_______________30
    Center Bore : 69___________69
    Depth(offset) : 43,7_________45
    cayenne stock rotor size for the rear is 330mm so evo x rotors are a perfect match for the rear too !
    cayenne rear calipers could be bought for about 200-400 a set
    930 turbo cayenne turbo rear calipers fitter
    adapter
    additional front caliper info:
    18Z cayenne turbo caliper_____2006 cayenne turbo S front caliper 19 Z_____2008+ cayenne turbo 19Z caliper
    Brembo 6 pot 17Z - pistons 34/36/38 total piston area = 3060mm2 cayenne s and some V6- V8 touareg Q7 etc these calipers use 330mm rotors stock
    Brembo 6 pot 18Z - pistons 30/34/38 total piston area = 2750mm2 cayenne turbo v10 touareg v12 Q7 etc these calipers use 350mm rotors stock
    Brembo 6 pot 19Z - pistons 32/36/38 total piston area = 2956mm2 cayenne turbo S and 2008+ these calipers use 380mm rotors stock..
    19Z calipers are much much harder to find but I did note a set of used 19Z calipers sometimes sell for about the same money (500-800$) as 18Z calipers.
    also what is worthwhile to note is that spare parts like pistons and rebuild kits are cheaper and easier to source for these ´cayenne´ calipers than for our stock 3000gt calipers!!!!
    for reference stock 3000gt vr4 total piston area: 2721 (2g 314mm rotor)
    17Z calipers would be an excellent choice too if someone wants to use smaller rotors like 330mm or so. many 17 inch wheels should fit very tight.. still a big big upgrade over stock calipers. 17Z calipers are also easier to source and cheaper.
    Cayenne 17Z 6 Pistons brake caliper on a 335mm rotor
    17" wheel
    pictures from http://www.goingsuperfast.com/Cayenne-calipers.html
    Touareg Brake Calipers (same as Cayenne)
    cayenne brake upgrade ???? what rotors????
  2. The Following User Says Thank You to mb7050 For This Useful Post:
  3. #2
    Two-piece rotor (Open Slot) - C63 AMG FRONT 08
    24lb, 360x36mm...$600 for a set of Rotors.
    FOOK YEAH
    just add calipers
    1996 GTO, Owner since 2003.
  4. #3
    600 each
  5. #4
    the Cayenne turbo uses 350mm rotors I think the evo rotors would be good match and cheap
  6. #5
    Cool! let us know how it goes.
    would love to get a set and just leave them the OEM black stealth big brakes lol
  7. #6
    Project EVO X Part 2, Making Great Brakes Even Better!
    wow the EVO X brakes look small :| I say look at the Q7/Cayenne side of things
  8. #7
    FWIW with the cayenne calipers you can probably do SOMETHING to get a 360x36mm rotor set in there...so that would make me happy too
    might want to look at the ability to run the brakes inboard as well! (would need custom knuckles or welds on the knuckles)
  9. #8
    Forum User verified Feedback Score 0 Caswell239's Avatar
    AB Canada
    So what adapters do you need?
    1991 GTO TT restoration in progress
    watch the progress from the start:
    http://www.3sgto.org/f2/my-complete-...ions-4545.html
  10. #9
    if he wants to move the Caliper to be inboard, you'll need to weld to the knuckle.
  11. #10
    The caliper isn't much bigger than a VR4 caliper, but the rotors are bigger. With the SCE wide rotor kit and good pads you can pretty easily be as good as an Evo (or BBK) for significantly cheaper.
