Ok first off I decided to start modding my dd 3000gt. My talon is fully done and I am bored with it. It is fast with a billet 16g (10.6) and after the shootout I will be running a 67 mm turbo, a new fmic kit, direct port nitrous for spoolup and a new intake manifold. But I have built 2 dsms already and they are easy to make fast and fun. But I dont really like their looks and they cant compare to the 3000gt in any respect for me.
So I was only going to use my vr4 for daily driver duties. Well I had it for a year, it did great in daily city driving, the winter, and long highway trips. It has been the perfect car. I took it down the track at NG11 and ran 12.4@111 with a 1.7 60ft. I was very surprised and got the urge to add little mods and build another 3S. It has been well over a year since I ran 11s in my FWD TT. The only mods the vr4 had with the 12.4 was a mbc @ 14psi, a cat back, a stage 2 clutch, aluminum flywheel, aluminum crank pully, metal y pipe, boost gauge, and thats it. It has the stock air box and stock downpipe/precats/main cat.
The plan.
SAFC 2
DR650s (old style) at 25psi at least or as much as they hold.
1050cc injectors
supra fuel pump hotwired
e85
my ebay fmic off my fwd tt
A new clutch if I need it
wideband
downpipe
I think that is it other than minor stuff.
I see no reason I cant run 10s in the daily. My other 2 e85 talons run 10s. My FWDTT ran 11.8@123 w/ crappy 60ft and only 18psi on 93 octane.
I feel that with e85 and alot of boost I can run 10s. Austin did it on 9bs and light weight. I feel with dr650s and moderate weight reductions it should not be too bad. I hope I stay with moderate weight reduction. lol. My last 3000gt was 2860lbs, and my talons are 2450lbs. , both without any CF or lexan.
Here is my real concern though. WHen I got the car, I did a compression test on the front 3 cylinders. Its a 91 so I never did it before on a 91. On my 94 I pull the crank sensor wire by timing covers. On this 91 I pulled the cam sensor plug.
A year ago I got like 90psi on 1, 140 on cyl 3, and 90 on cyl 5. That was after 5 cranks and warmed. I said its either wrong or the engine is hurt but I got it for cheap and it was only my dd. Anyway, I drove it a year, it never smokes at all, never had a lack of power, never consumed alot of fuel, never trashed oil, it has been great. I get 26 on the highway. Then I ran the 12.4@ 111 to my surprise at ng11. I was hot lapping and it was consistent. And then I have been racing around town alot too. And I drive it hard and it still runs perfect and still mid 12s when I went back to the track 2 weeks ago.
So I put those numbers in the back of my mind and considered it either wrong reading or that I was doing the test wrong. I re did it today because I am getting ready to do these mods and dont want to start on a hurt engine. Car is still running great, no smoke, fast, ect. I do the test.
Cylinder 1 goes to 60 on first compression stroke, 90 psi on second and levels off at 105psi. Cylinder 5 is identical. Cylinder 3 goes to 150 after about 4 -5 compression strokes and stops.
Now I am asking for help/questions. I have built 2 dsm engines/setups now from scratch and have been focusing on dsms for a while and have got rusty on the 3Ss. Can anyone tell me if pulling the cam sensor is the right way on a 91? Also can someone tell me what could cause the numbers to be low but it running great and IMO reading wrong. I did a wet test and they all stayed the same. I know the rings are fine. No smoking, great power, no oil consumption, no trashing the oil with fuel., ect. I dont know. What do you think it could be? Is there actually a problem with the engine? Why are the numbers like this? I truly think it is just a bad reading or I am doing it wrong. How could it run so good and so long and be that low. That is below the service limit and is way off from each other. COuld the valves be not sealing well but still run great?
I take out front 3 plugs, pull cam sensor plug, screw tester in hole, floor the gas and crank car 7 times when already at operating temp. What could be wrong. I do compression tests weekly in my DSM and never have problems. I just feel there is an error making the readings low. Could I really have 100psi in 2 cylinders and have no ill effects?
Thanks for the help. I feel like a newbie. I know alot about these cars and DSMs and never had a problem but I feel lost here. Mainly because I feel I have been from the 3S scene to long and am over looking something stupid or am doing the test wrong for a 91 vr4. I havent worked on one in well over a year! I never even open the engine bay on this dd.
