Results 1 to 10 of 11
Thread: Here's a 60k issue that I've never seen before.
    West MI
    Front cover and belt damage
    Hmmm whats this sticking out of the rear cover
    How did that get their
    And the culprit.
    All oem parts were put on 20-30k miles ago, I've done so many that I can't say for sure I checked the m6x1 water pump bolts that mitsubishi uses to hold the water pump together. Maybe they forgot the loc-tite? Either way make sure to check these bolts before throwing your water pump in. The belt was 1 tooth off, not sure of any damages yet but it was running just fine when I got it.
    good god, man!
    Stuper Moderator Feedback Score 0 HilbillyHomeboy's Avatar
    January 2003
    That's. Different.
    Douches
    I've never seen that happen. I'm sure the valves are OK. Mine was a lot further off and I barely bent one valve. I'd probably reset the timing and do a compression test first though.
    Riding topless!! verified Feedback Score 0 Gearheadvr4's Avatar
    Owned 8 3s since 2005.
    Corpus Christi
    I'd say your lucky. Could have been much worse.
    Wow, I wish I had your luck.
    SoSoCal verified Feedback Score 1 (100%) DuTTch's Avatar
    where did the bolt come from?
    Southernmost 3S Owner supporter Feedback Score 0 93STLTH's Avatar
    Key Largo, FL
    Quote Originally Posted by DuTTch View Post
    He said it's from the water pump. One of the bolts that hold the 2 halves together.
    2013 NG: 1st place, FWD Drags
    Fowlerville, MI
    Was this Mark's car?
    West MI
    Bret's
