Results 1 to 10 of 11
Thread: clicking noise???
    clicking noise???
    So i have this really annoying clicking noise that only arises when i try starting the car, the car starts really fast so im postive it has nothing to do with the ignation. the noise seems to be coming from somewhere on the passenger interior. behind the glove box maybe??? Its not mechincal i can tell that much it sounds like somthing electrical. correct me if im wrong but is there not somthing to do with the blower motor behind there? that only comes to mind becuase my car wont blow any air what so ever out of the ducts. would really hate to tear the car apart on just a hunch. anyone else have any suggestions? Or im i on the right track?
    Motor: 3.5 6g74, 3sx lw pulley, Maximal solid mounts, 8.5mm msd wires, Big tyla ground wires
    Drive Train: Spec stage 2, Rps lightweight flywheel
    Fuel: Ohhnoo ss fuel loop, TT fuel pump, TT fuel pump assembly
    Nitrous: Zex Wet EFI Nitrous Kit, zex bottle heater, Zex purge kit, Zex no2 gauge, Nos window switch, Weevil custom ashtray nitrous switch panel
    Managment: Autometer A/F gauge, Hand Held Halo dataloger, 3sx in bay fuel pressure gauge
    Suspension: Front and rear ultimate performance strut bars, Megan springs, Saleen wheels
    Intake/Exhaust: Generic cone filter intake and arm, Ultimate performance intake box, 3sx downpipe, 3sx test pipe, Megan catback
    look Good: 3sx plug cover, 3sx engine covers, Polished plenum, Polished valve covers, Polished fuel rails, 3KGT2NV allen bolt ss kit, 2g black garnish, Rear active aero transplant, Jdm snake eyes
    Interior: Custom two tone leather, Pioneer dvd, Alpine speakers, Alpine 4way amp, Ultimate performance door sills, Razo shift knob, 3sx Aluminum Pedal Covers, dual piller pod
    wasting my money on a NA since 2009
    Dallas TX
    You're sure it's not the starter clicking? It may still turn the engine over and start, but from what you're describing and the location, it sounds like the starter is on its way out.
  3. The Following User Says Thank You to UTRacerX9 For This Useful Post:
  4. #3
    no i dont think so, you can only hear it from inside the car.
  5. #4
    Cazenovia, NY
    Sounds like the MFI relay under the passenger side center console carpeting.
  6. The Following User Says Thank You to x2xtreme360 For This Useful Post:
  7. #5
    Quote Originally Posted by x2xtreme360 View Post
    would this cause a lean condition? i have replaced my fuel pump, fuel pump assembly, injectors, fpr trying to track this down, im going to be a little ticked if it was simply a relay. whats the procedure for testing it is it the same as this dsm guide?MFI/Fuel Pump Relay - DSM Forums
    thanks
  8. #6
    Cazenovia, NY
    Test it as you would any other relay. The clicking noise is probably it malfunctioning, if it does it while you're driving, and yes, it DOES control the fuel pump relay.
    Now, this could also be from a bad ECU (if you have a first gen).
  9. #7
    No it does it when i turn the key in the ignation
  10. #8
    Cazenovia, NY
    Yea, it's supposed to.
  11. #9
    it's suppose to click? as in its not a problem?
  12. #10
    Sounds normal to me, I don't believe it will click more than once as you start the car though.
