Okay, is it common or even possible for there to be oil leaks at the head gaskets but no coolant leaks? I just swapped a whole bunch of gaskets because I was a douche and bought the Eristic gasket set, which hasn't done anything but cost me more time and money than anybody wants to commit after having thought they fixed it in the first place.
After the first hundred miles on the new gaskets I didn't notice any leaks besides one of the rear cam end caps that I hadn't received in the mail yet when I needed to put the car back together (that seal is another issue on its own). I replaced the valve cover gaskets and spark plug gaskets, which were all leaking like crazy. I also swapped the front head's end caps and haven't had any problems with the new gaskets as of now. I finally noticed some drips coming from the top end of the engine on both the front and rear. From what I can see, the valve cover gaskets are doing their jobs, the turbo oil drain line gaskets are still sealed, as are the cam seals. Pretty much everything I have tinkered with is sealing correctly for now *knocks on wood*. But when I looked from under the car it appears that the leaks are coming from where the heads bolt onto the block. I have head gaskets but god knows I don't want to replace those![]()
To get back on track, can the head gaskets leak oil and not coolant? If it is leaking out is there a chance that I have excessive crankcase pressure that is not being ventilated out through the pcv valve? I wiggled the little guy and it clicks so I am assuming the valve is in working order. Are there other ways to check to ensure that the system is working correctly? I looked up Krank Vents and think I came up with more negative reviews than positive regarding their function. Were excessive pressure my problem, would a catch can help out in place of the valve?
Man...I'm a bit frustrated with this whole ordeal but dammit I need to figure it out to be happy with the car! Grrrr
Thanks in advance to any responses!
