Do you have a resistor pack on the firewall near the battery? It's an aluminium thing with lots of wires coming out to a plug. Also if your installing a tt ecu and harness you will have a plug for it.
Sent from my GT-I9300 using Tapatalk 2
Waiting install
Build Thread
'95 Mitsubishi GTO AWD ATX - '99 front end conversion, TT conversion (19Ts), Forced Four shift box with paddle shifters, A/A wing, LCDBC, 3" straight piped exhaust with no cats and gutted pre-cats, Custom rear diffuser, HIDs, Carbon fiber steering wheel, 18" Mustang Saleen replicas.
'92 Dodge Stealth ES - 3KGT body conversion. Sold!
Obviously one of many ways to do it:
Fuel System
Are you sure you don't have one? According to ASA with your vin number you have the resistor. This part should be mounted to the firewall.
To add one to an na you basically just put it in line, ill grab some pics tomorrow with more details.
Why would my car have it if it has the N/A injectors? I will check anyway...
LeRoyDL,
I would appreciate that!
Well, I checked and there is no transistor pack on the fire wall or anywhere else in the engine bay that I can see. I expected that, because it doesn't make sense to install transistor pack if you don't need it. Why spend the extra money? There is a posibility that the wiring could have the connector for the transistor pack, but I doubt it. I do see a lot of connectors that are just sitting there with nothing plugged into them... I always wondered what they were for! I will take some pictures tomorrow, if I don't forget, and I will post them here to see if anyone could recognize what some of them are for.
