I need help pulling the front passenger side axle out. I can't get the end out of the transmission. Need help asap thanks in advance
Take an air hammer or a deadblow hammer w/prybar and set it on the flat edge of the step on the bell that rests right against the transmission. Smack it towards the outboard till it breaks free. It will come out.
I think I do the same thing Jfast does (my auto vocab sucks). Get as much leverage as you can on something that you can slip between the axle (this part must be bell J mentioned) and transmission. Once you can get a good bite in there without it slipping out it's just a matter of forceGL!
Sometimes a burr happenes around the clip and makes it tough to get out. If a large prybar doesnt knock it loose, use two 180 deg. apart, and pry with the longest one.
-SP
Pry bar. If that doesn't work, bigger pry bar. Pry like a man. A real man. If that fails, mini-sledge and a large flat chisel usually does the trick for me.
Kind of like when your ignition key won't turn cause the steering wheel lock, try rotating the axle back/forth as you pull. This worked for me, no pry bar needed.
* Evo8 MAF * TD04-16T * Delphi 780cc * FIPK * Full Custom Exhaust * Hotwired Supra FP * Megan CO *
* GReddy FMIC * Nitto 555's * Avic Z3 * BlackStealths LCD/BC *** All else stock *
how do you even get at the thing? i've been out there for an hour now and have succeeded in making several of my knuckles bleed but thats about it. There is no trick other than brute force?
Real long prybar from the bottom.
I remember this it was not fun.
You're making it harder than it needs to be.
The car is on jack stands I can get about a foot of prybar under there. I was assuming I was making it harder than it needed, to be that's why I'm asking for advice from people who have done it before me.
