Compression test
95° ouside engine cold
1 - 140
3 - 140
5 - 145
2 - 140
4 - between 135 and 140(137.5? Lol)
6 - same as 4
Is this good?
Compression test
1 - 140
3 - 140
5 - 145
2 - 140
6 - same as 4
Is this good?
1991 Dodge Stealth ES - Sold
Sold.
I guess once I get my.front turbo rebuilt and it all put back together.I'll do it again but warm..
I get around ~130 on cold engine, but i'm not sure if the car not being run for a week beforehand makes a big difference (piston rings probably dry). also have cams so that might make a tiny difference
I still get an average 140 with 219k on my engine.
I haven't run her in weeks.. and its stock internals. Looks like my oil was only front turbo bad heh...
My engine is about 150-160 with Wiseco pistons.
mine is 125-130 on all forged internals. came like that form laniers speed shop. he bored it a bit larger than .060 to handle taking a beating. he builds 7 sec drag cars btw![]()
mine was 150ish. but its more about the % difference between cylinders. your engine is fine
