Subscribed.
Subscribed.
He has seen many of these ecus open and has a reference ecu. I cant see a reason to say otherwise, cause its easy to take a look. I too have an sl ecu and can get access to a reference 99 ecu. Ill take his word that the sl may be a more sensetive circuit. If for some reason its not, ill see that later. The real work on this project is in the ecuflash file. Keep up the good work! Brett, when will the ecus be ready for sale?
I have the knock issue resolved.. I also have the timing issue resolved.. When the ecu is from a distributor based car.. I am working on the o2 circuits..
Basically the 3000 dohc na and turbo use 4 o2 sensors.. All others use two, one front and one rear. Modifying the circuit to use two front is the last major hurdle.. Right now the montero and diamante ecus are only reading the front bank o2 and we all know that is not ideal.. I should have it soon..
Also I have the reason why you see ghost o2 voltages when there are no sensors.. It's inerrant in the hard circuitry.. I will provide a more detailed explanation later
Yeah so I took the diamante ecu put it in my 99VR4 and tested the different O2 sensors readings. I was concerned about the missing O2 sensors on the diamante. Since I have two Lc1 wb o2s I can manipulate each of the 4 channels coming into the ECU. Well long story short the daimante ECu reads the front and rear upper (precat) o2 signals correctly. I couldn't really test the postcat o2 signals because I don't know the MUTIII readout for them.
also the 98/99 sohc 3000gt had four O2 sensors... so the 98/99 SOHC 3000gt would be better than the Diamante ECU. It would be the same as 98/99 SL ECU if the start timing issue is fixed.
www.Chromedecu.org
2 year Warranty on all ECUs.
How To Contact Me:
eMail: apape10@yahoo.com
3SI: Jesters Deadd
www.Chromedecu.org
Code:Knock circuit layout 1998 3000GT SL MMC P/N MD347251 MFG P/N E2T61389 H3 PCB P/N JE331B157D Con1-Pin 91 > R314 (TOP) > C45 (BOTTOM) > R315 (TOP) > IC2-Pin 78 < IC2-Pin 80 > IC1-Pin 92 R314 = 51 KOhm C45 = 0.02 uF R315 = 6.2 KOhm IC2 = Mitsu Electronics E328 logic level converter IC1 = Renesas H8/539F microcontroller, A/D input 6 1999 3000GT VR4 MMC P/N MD360163 MFG P/N E2T61495 H1 PCB P/N JE331B32804B Con1-Pin91 > R71 (TOP) > C62 (BOTTOM) > R73 (TOP) > IC7-Pin 78 < IC7-Pin80 > IC9-Pin 92 R71 = 51 KOhm C62 = 0.02 uF R73 = 6.2 KOhm IC7 = Mitsu Electronics E328 logic level converter IC9 = Renesas H8/539F microcontroller, A/D input 6
Coop, I tested this. You can run it by just deselecting some of the peripheries in the code. Since I have two Lc1 wb o2s I can manipulate each of the 4 channels coming into the ECU. Well long story short the daimante ECu reads the front and rear upper (precat) o2 signals correctly. I couldn't really test the postcat o2 signals because I don't know the MUTIII readout for them. But it also depends how you set up the O2s. If you go front and then back bank it works fine. If you go pre cat and post cat there is a periph that changes the two banks to osilate on the same O2. but testing needs to confirm this still.
