Just so this information is here too. I dissasembled a board and it had 4 layers. The "blind via" doesn't attach to anything. I think this is conclusive.
www.Chromedecu.org
2 year Warranty on all ECUs.
How To Contact Me:
eMail: apape10@yahoo.com
3SI: Jesters Deadd
www.Chromedecu.org
Adam, burning through the board with a propane torch is hardly conclusive. The 1/2 mm traces would burn off before you even noticed them.
But I am working on the problem with several others and should have verifiable conclusive test results when I get back from the KC area.
On another note, fun with an o-scope chasing down the knock sensor circuit...
https://www.youtube.com/watch?v=pGrc...e_gdata_player
Blind%20Via.jpgLayer%202.jpgLayer%202%20close.jpgGround%20Layer.jpgLayers%20Corner.jpgIt was butane. And there are no 1/2 mm traces in the inner layer. I was worried the inner layers would be as complex as the two outside layers. However I was pleasantly surprised that the inner layers were pretty simple. The ground layer, we will call it layer 3, was like one big block. The other layer, we will call it layer 2, had large blocks that would connect certain pins. I found pins that connected to the blocks the blind via went through and checked for continuity with the blind via. I conclusivley can say it doesn't attach to an inner layer. In fact there are many that go through the board and don't attach to an inner layer.
What he's saying is that the via may attach to those big blocky inner layer pads via tiny traces. Those tiny traces could burn off before you ever see them.Originally Posted by Adam
I've seen those traces on the older PCBs. They radiate out from the via like a small X. They're bigger and more visible on the older ECUs.
oh I gotcha. You can actually see some of the vias that go through the board and attach to the blocks if you look in my pictures. The knock ground pin is a perfect exacmple. Also I found pins that connected to the blocks that the blind via goes through.
On an unmolested board I checked for continuity with the blind via with at least two other pins. Those pins I know connect to the block the blind via passes through.
Am I clear about what I did? I am sometimes not the best at explaining my madness. But there is a method to it.
I guess you just don't get it...
looks like you lifted a pad or two with your torch![]()
a little late to the party, but that's not a blind via. You rarely see blind (or buried) via's used in any pcb bc it vastly increases costs, and rarely necessary.
On a 4 layer PCB, the inner 2 layers are typically reserved for GND and VCC planes. You can see that via runs straight through a plane on both inner layers. If it connected to either you'd be able to see it with a flashlight & loupe (it wouldn't be a 6 mil trace, it'd look similar to the via on the resistors above it (R300 / R315)). Also, easy to meter it against both planes to make sure like Jester explained.
You guys posting schematics, care to post your eagle file? I'm curious to see the schematic and how much of it is mapped.
