Results 1 to 7 of 7
Thread: TT conversion kit
    Forum User Feedback Score 3 (100%) toddrs93's Avatar
    Hagerstown,MD
    TT conversion kit
    Fortunate to get ahold of a clean car with low mileage turbos.
    This has everything you need to convert an N/A to a TT with the exception of some kind of fuel controller or TT ECU.
    All the parts have been thoroughly cleaned. No oil in anything, very very small amount of shaft play in these turbos, I have felt more in new turbos.
    Both precats have been gutted, EGR has been welded shut.
    New oil filter, plugs, oil pan gasket maker, vac line, and water lines will also be included.
    Pics to follow
    $800 plus shipping
    This is a very clean kit
    Front and rear stock turbos
    Front and rear exhaust manifold
    Front o2 housing
    Front gutted precat
    Rear gutted precat/o2 housing
    Turbo downpipe
    Both intercoolers
    All intercooler piping
    Oil cooler and lines
    VR4 Oil Pan
    Both o2 sensors
    Front and rear wastegates
    All turbo coolant lines
    Both oil feed lines
    Both oil return lines
    Y-pipe
    Intake bubble
    Both intake pipes
    VR4 fuel injectors
    VR4 fuel pump
    Water/thermostat housing
    VR4 front motor mount bracket
    Rear turbo oil feed joint
    All associated nuts and bolts
    Set of new Autolite spark plugs
    New fram oil filter
    New oil pan gasket maker
    New vacuum line
    New water line
    Hagerstown,MD
    Rancho Cucamonga, CA
    mmmmmm so clean! GL w/the sale!
    Quote Originally Posted by MADMarc View Post
    It's a good deal also.
    Hagerstown,MD
    more pics
    Hagerstown,MD
    oil pan, piping
    Forum User Feedback Score 0 Danube_3KGT's Avatar
    would you take 600.00? pm me if interested
