Results 11 to 20 of 36
Thread: Passenger door won't opn
    I'm Kind Of A Big Deal
    Push the unlock button from the inside HARD and force the handle. Does the handle give resistance? Or its just not catching on anything?
    Current:
    2004 ML500 - Mommy Mobile
    1995 3000GT VR-4 - lawn gnome
    1999 3000GT SL - 7,436 miles
    FOR SALE:
    JNS Engineering verified
    San Jose, CA
    Quote Originally Posted by dpartinvr4 View Post
    Sawzall
    I MAY get to this point if this darn thing doesn't open soon
    When I push the unlock from the inside it fails to go all the way over like there's a mechanical resistance. After doing this when I pull the outside handle there's a slight bump like it's trying but it doesn't catch.
    I found this on the other site which seems to be the solution. Passenger Door unlock... instant relock FIXED!
    Problem is I still don't know how to defeat the latch to get the door open in the first place
    just push really hard, and force the handle. if that doesn't work, you're cutting out your interior panel to get to the door internals.
    San Jose, CA
    Interior is already out (repaint project). I can access the latch and actuator already, I just can't figure out how to trip the latch.
    If the interior door panel is out, then just disconnect the rods going to the electric door lock actuator and you should be home free.
    San Jose, CA
    Already tried that. There is something jamming at the latch.
    did you take the arm off of the handle and try manually moving it?
  8. #18
    San Jose, CA
    SUCCESS!
    With the window up I stuck my hand into the latch mechanism while operating the interior door lock and found a way to open the door. Now I need to take the latch out and see what the hell is wrong with it.
  9. #19
    Dayton, Ohio
    Woot
    Glad to hear this Jim....post up pics of the mechanism once you get it out!\
    Bob.
    Stock 18" 6 Spoke Chromies
    Indiglo Gauges
  10. #20
    San Jose, CA
    See the white plastic? Just to the right is a prong that normally rests on a rubber pad inside that plastic. The rubber is a bit compressed so the prong moves too far and prevents the lock from fully opening
