So I have been prone to the notorious trans rattle. My first though was the throw out bearing. Picked up a brand new one swapped it out and the rattle is still there. At a local meet I spoke with Chris "Ninja Performance" and he said it sounded like the input shaft bearing. Made sense so I picked one up from GZP, dropped the trans again to swap out the bearing. Needless to say both the old throw out bearing and the old input shaft bearing looked fine when removed.
Guess what! the damn noise is still there...WTFH!!!!
So I am getting annoyed that I have dropped the trans twice and replaced to perfectly good parts and the damn noise is still there.
I have checked specs on all bolts, Flywheel was resurfaced and clutch is new OEM. It usually goes away when I push in the clutch which lead me to believe the throw out bearing.
So my question to everyone that has had this issue, how did you get it fixed??
Any other ideas what could cause the rattling noise?
