Car is a bpu 92 vr4. Mods are Intake, turbo back exhaust, fmic, fuelab fpr, hotwired walbro, Wb02, forge bov, ngk copper plugs, new wires, new o2 sensores, stock turbos.
I just had the car at GZP for my 120k service, which they did an excellent job doing and I had it back in 2 days. I have massive oil pressure now. But the problem is ever since I got the car back, its been running much leaner than before. I'm 99% sure the problem is unrelated to the work they did, and just a coincidence it happened now. The car went in with an idle afr fluctuating from 14.3-15v and cruise from 14.5-15.5v exact. When i got it back idle was at 15.1-16.3v and cruise is at 14.4-16.8v sometimes hitting 17:1. Also on hot starts, O2s trims will rise up in the 130 range for a few minutes, then drop down to normal. Hans and I both checked for vacuum leaks and there are none. Fuel pressure is at 43-44psi base pressure. Hans told me both o2s are cycling. Any help would be appreciated.![]()
