Results 1 to 9 of 9
Thread: just swapped wastegates, springs are sooo different..pics
    Pueblo, CO
    Well, decided to try it and rebuild both stock wastegates withe the wrx ones i got from Hyde. (great guy btw). well, since i have two wrx waste gates that are the same, i figured to try and rbuild them. well, first, pulled apart the stock and then the wrx and couldnt believe the difference. swapped em out and makes quite a bit of difference. here is a pic of the two springs. the smaller (and thinner) is the mitsu. The wrx was alot stiffer too and when i get my exhaust housings back I will put it all back together and hopefully it holds together. the banging and crimping is a bitch but all in all i think i did a good job. we shall see
    Pueblo, CO
    Pueblo, CO
    Pueblo, CO
    lol stocker vs 19t
    Pueblo, CO
    wow guess no one cares about this? Hmm..
    Forum User verified Feedback Score 2 (100%) J-Groove's Avatar
    What psi is the WRX wastegate set to?
    OEM 9b is 6 pounds...I think.
    Member verified Feedback Score 1 (100%) aaronatstate's Avatar
    July 2005
    Rogers, AR
    WRX is 9lbs
    Thermal Engineer- Mmbr Since:8/2005 verified Feedback Score 0 Alex3000gt's Avatar
    Ann Arbor, MI
    Why do some people weld waste gates shut?
    Riding topless!! verified Feedback Score 0 Gearheadvr4's Avatar
    Owned 8 3s since 2005.
    Corpus Christi
    External wastegates. My 3SX td05 kit has externals.
