Page 7 of 7 FirstFirst ... 567
Results 61 to 70 of 70
Thread: Single Turbo setups...
  1. #61
    Apr 2011
    Mid-April 2011.
    Monroe WI
    n/A manifolds and downpipe r perfect mock up for a cheap/ Easy single turbo manifold
  2. #62
    Sep 2011
    I know you prefer in front of the trans vs over but here's pics of my single setup running a holset hx52 with the billet comp wheel. Its on a base flash tune at 14psi on e85 for right now. As is, full boost hits at 4500 on a 1.2ar/16cm hotside on a 3.0. Hoping with some further tunning to drop that by a few hundred rpms and be able to up the boost and then add a shiver spool valve on top of that. According to VD, it hits 389awhp at 14 psi, so im excited for results when I up the boost! Here's some pic's and a vid of my messy setup below...
    Don't mind the thermal material on the windshield, I was cutting it to fit along the firewall and to protect some wiring and lines, I just saw the car in the sun and thought "damn, not half bad" and snapped a pic
    Here's a pull below in 3rd at 35-40 rolling (tranny doesn't have 2nd currently, thats on the list as well as the Ray's brace and tilton sitting on my shelf )
    Skip to 27sec in as i didnt realize he was filming me at the time of my maiden voyage after having finished the build and working out the major bugs the week prior....
    for what it is, i think its doing alright
    Hx52 billet 67mm comp wheel, 350Z headers, Custom 4" exhaust, STM avenger intake mod, Denso 1250's, twin walbro 400's, dual pump/dual feed braided lines from tank to rails,Tial 50mm BOV, Tial 60mm wg, Spec 4+ with hub welded and balanced, Rays Bellhousing brace, flash ECU with openport 2.0 tune, MSD coils with KB boost a spark, MSD race ignition wires, Odyssey PC680, CX racing fmic 1000hp core 28x12x4, ABS delete, EGR delete, AC delete, cruise delete, pansy patrol pulley reduction, Vac reduction
  3. #63
    | @/|/| +|2()|/| verified
    December 2009
    Fox Cities, WI
    Is that a sebring/eclipse intake? I plan to move the thottle over on driverside.
  4. #64
    Sep 2011
    yessir, with a 6g72 TB flange off the intake manifold welded onto the avenger one so i could attach the stock turbo tb, then just a 4 ply 90 degree elbow coupler thats 2.75" inches on one side and 3" on the other for my IC piping.....
  5. The Following User Says Thank You to arm0red1 For This Useful Post:
  6. #65
    Apr 2011
    Mid-April 2011.
    Monroe WI
    Where in Wisconsin R u located? Lived there for 15 years between Janesville/Madison/Fort Atkinson. I live in rockford IL right now.
    Its a nice setup ive seen that video before. Wouldnt mind some more videos.
  7. #66
    December 2009
    Fox Cities, WI
    Ha ya, maybe we can have a single meet and greet.
    No homo..
  8. #67
    Sep 2011
    haha sure sure, I live in Eau Claire WI, in the central part, and have a bunch of friends going to the U in madison, so I usually head down there for the parties or badger games If homework isnt an issue. I'm hoping to get it to the next midwest gathering in 2013, I'm just trying to work out the end of the build kinks and get it to a state of "reliable" enough where I would feel comfortable enough to drive the car across a few states. Needless to say, after just getting out from under the knife, its giving me it's issues when they arise. Driving to the all mitsu cookout from EC resulted in me popping the ECI fuse midway up to meet with Curt Gendron and MN3s. Twin pumps shut off and luckily one of the guys had a trailer. My cross pipe is thermal treated and double wrapped, and the turbo has a t4 blanket, but that didn't stop the heat from chapping/cracking the wire casing for the harness loom that runs on top of the transmission, causing a dead short- which is why the ECI fuse was popping. I repaired the 15 year old wire casing with heat shrink, rewrapped it in DEI cool tube, buttoned it back up and away I went. The other issue is the car has a constant oil drip at the drain fitting on the oil pan for the -12 line. I'm going to take the pan off and install a -12 bulkhead fitting to hopefully solve the oil drip problem. After that is my next tunning session to dial the car in some more and run a little more boost, I'll try to get some more video's then. The car will probably start smoking the stock clutch at 17 psi or so and I'll need to seriously start looking at getting my transmission repaired with a new set of synchro's, a brace installed, and the heavier clutch installed. While im in the drivetrain, and for a little extra coin I may grab the beefiest transfer case cage for my 6 speed. It does nothing for the housing, but in the billet gears thread, the latest theory on why gears break is that the housing itself flexes, and the 6 spd transfer case gears already suffer from the fact that they don't utilize full contact surface on the teeth of the gears. So when the housing flexes just that little bit, the gears briefly splay apart, mis align and the torque does the rest of the damage. I don't have the spare change for a billet end case atm, but hopefully this helps to reinforce what it can, especially for the measly price of 150 bucks or so.
  9. #68
    bslade
    Guest
    A Friend of mine suggested I post up my single turbo setup on here. Generates a TON of heat. Everything (turbo, headers, downpipe, battery, Cooling lines) is wrapped now.....
  10. The Following User Says Thank You to bslade For This Useful Post:
  11. #69
    December 2009
    Fox Cities, WI
    That exhaust 2.5 inch? Whats the turbo?
  12. #70
    1993 rt/tt Not Verified
    wa state
    Quote Originally Posted by bslade View Post
    Interesting, where is that setup from...custom?
    edit...found the reference on your page
    The Single-Turbo setup, including turbo, intake, headers, exhaust are all custom made (stainless steel) for this car. GT designed the whole thing.
