I wanted to put a couple of pounds of pea gravel in it and wrap it in a blanket and put it in the dryer but I was afraid my wife would shoot me.![]()
R.I.P Spyder you are missed.
93 VR4 453 Hp, balanced, Ported, Polished, Port Matched, 99 lifters, Ross 70 over 8.5 to 1 forged pistons, Stress relieved shotpeened magnafluxed rods,EK2 Red poly motor mounts, Fidanza Adjustable Cam Gears,Kevlar timing belt, Polished Fuel Rails, 16 T, Gutted Precats, 3SX performance down pipe, Race pipe,QTP Exhaust 3" Cutout, HKS Cat Back, MSD Wires, NGK BCP7ES non-resistor plugs, AEM EMS ECU, Speed Density Conversion, AEM 3.5 MAP, AEM AIT,Dual K&N air filters, Dejon Tool Dual Air Intake, Dejon Tool Y Pipe, PTE 550, Walbro fuel pump, EK2 fuel loop, No EGR, Vacuum line reduction, AEM True Flow Controller, Greddy BOV, AEM Gauge UEGO Controller wide band O2 sensor, Gauge-Tech, Kormex tranny,Quadco XR steel Output shaft, LSE Stainless Steel Transfer Main case and Midcase, Quadco input spool, Lightened flywheel, South Bend 6 Puck DXD F Clutch, Greddy EGT, Autometer Boost Gauge, 3SX fuel pressure gauge, Cross Drilled and Slotted Rotors, Ceramic Brake Pads, FMIC , 5Zigen FNO1R-C, Audio: 6 New Infinty speakers. Alpine CDA MP3/WWA 9847 Reciever, 2 Dual 300 watt amps. Cianci 3 gauge A pilars, Aluminum defroster vents' lowered
BTW this is a pressurized tank that I need to go with my 1957 5.5hp Johnson outboard that I'm restoring as a hobby. My family had a 1957 35hp as a kid and they look identical. The older motors worked off of pressurized tanks which are no longer available.
I don't own a bullet proof vest.![]()
DISASTER! the table holding the tank collapsed. The plastic shoe box shattered. I filled 90% and started it again. I'll stick another shoe box on it tomorrow. I took the opportunity to examine the bottom and it is 70-80% clean. A couple of of more days should do it.
I've done some of this while restoring some implements. Used a section of large angle iron at first. It worked faster than the rebar that I tried later.
The biggest problem like you said is constantly cleaning off the electrode, whatever you stick in there that has a closer surface area to the part you're working on, the better. I think metal grating would work well for this.
Still trying to find a good way to filter the phosphoric acid.
^^^ good observation ^^^^ The bottom is spec and span now I need to put the shoe box back on so I can clean all of the top.
