Page 3 of 3 FirstFirst 123
Results 21 to 24 of 24
Thread: 93 motor will not turn, just rebuilt, just installed.
    Quote Originally Posted by Tackhammer View Post
    The 1 time i didnt have a TC lined up properly the trans wouldnt even come close to the block to put the bolts in the bellhousing so i doubt its the TC
    +1 was not TC/Tranny problem
    Yea, i would check the starter first since its the easiest thing to check, and the only thing that is different than when the motor was hanging from the crane. Remove it and see if the gear is stuck out and if the engine will turn with it removed
    +1 starter gear was not stuck out but was the fix.
    Quote Originally Posted by BadHabit View Post
    loosen the bolts up on the starter just to be sure it is not locked into the flywheel.I had that happen a couple of times on a ford I had..
    just my 2cents
    BH
    +2 WINNER!!! (cue loud brazilian soccer announcer) "GGGGGGGGGGOOOOOOOOOOOOOOOOOOOOOAAAAAAAAAAAAAAAAAA AAAAAALLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLL LLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLL LLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLL!!!
    As annoying as it is, the ford problem occurred, removed the starter checked to turn the motor by hand, it turned, reinstalled starter, tested it, it turned. yay, except not, now that the motor turns i've got a new issue, i'm not getting fuel.
    had a spare TPS and fuel rails and injectors so they've already been swapped over, these parts are all confirmed working. Tried advancing and retarding the CAS, with no affects. tried with and with out MAF, the only time we got it started was with starter fluid. will not idle and dies as soon as the starter fluid goes away, regardless of pedal position.
    any ideas?
    EDIT: forgot to add that the fuel rails are pressurized, though i do not know if they are not staying pressurized or if the injectors are not being told to open.
    3/S: So bad ass they don't have to use chinese stars to pick locks and steal cars.
    RX7: Umm... yeah, I always shift at 7k.(sold )(Killed by dumb ass)
    Honda: "More forward please!"
    Good work!
    to hear if they are open, get someone to crank the car and place a long screwdriver on the body of one injector, you should hear it ticking (like a stethoscope)
    N.C.
    YEAHHHHH,I finally won something!!!!!
    all kidding aside,glad it helped
    BH
  4. #24
    Good work!
    I'll give that a shot when i get back home today
    BH
    I was hoping all day yesterday that thats what it was.
