my friend has an 05 GTO 6.0 and It's a blast, the tremec 6spd is amazing. the IRS is good and bad. good in that the thing is a drift machine, and kicks out so nice, and makes anyone look like a bad ass, but bad in that wheel hop sucks. also, the cam in that car is basically maxed out from the factory. scott got headers, full exhaust, a cold air intake, and had it professionally tuned by people who specialize in GTO's, but it now runs a second slower in the quarter, and pops like crazy below mid 3000rpms. this will be fixed with a cam, and it will be a ton faster with the aforementioned mods, you just have to get a cam before anything else will really work.
EDIT: what about a genesis turbo, or i think the 2012 model genesis is supposed to have a v8 option?
R.I.P Spyder you are missed.
93 VR4 453 Hp, balanced, Ported, Polished, Port Matched, 99 lifters, Ross 70 over 8.5 to 1 forged pistons, Stress relieved shotpeened magnafluxed rods,EK2 Red poly motor mounts, Fidanza Adjustable Cam Gears,Kevlar timing belt, Polished Fuel Rails, 16 T, Gutted Precats, 3SX performance down pipe, Race pipe,QTP Exhaust 3" Cutout, HKS Cat Back, MSD Wires, NGK BCP7ES non-resistor plugs, AEM EMS ECU, Speed Density Conversion, AEM 3.5 MAP, AEM AIT,Dual K&N air filters, Dejon Tool Dual Air Intake, Dejon Tool Y Pipe, PTE 550, Walbro fuel pump, EK2 fuel loop, No EGR, Vacuum line reduction, AEM True Flow Controller, Greddy BOV, AEM Gauge UEGO Controller wide band O2 sensor, Gauge-Tech, Kormex tranny,Quadco XR steel Output shaft, LSE Stainless Steel Transfer Main case and Midcase, Quadco input spool, Lightened flywheel, South Bend 6 Puck DXD F Clutch, Greddy EGT, Autometer Boost Gauge, 3SX fuel pressure gauge, Cross Drilled and Slotted Rotors, Ceramic Brake Pads, FMIC , 5Zigen FNO1R-C, Audio: 6 New Infinty speakers. Alpine CDA MP3/WWA 9847 Reciever, 2 Dual 300 watt amps. Cianci 3 gauge A pilars, Aluminum defroster vents' lowered
