Results 1 to 10 of 15
Thread: TD04-13g's
    TD04-13g's
    What is the max AWHP that I can expect from them?
    I have:
    AEM series 2
    HKS D2 catback
    Fuel pump hot wire
    Know I need to get / do:
    Down pipe
    Gut pre-cats
    Remove main cat
    550 injectors
    Fuel pump upgrade
    Before I discovered that I had 13G's I was all set for DR700's. But after NG, I am thinking that maybe tapping the full potential out of the 13g's might be enough.
    I figured that if I spent that 3K on other things than DR700's I should be able to get the most out of the 13g's that I already have.
    Anyone have thoughts to offer?
    Yes.
    An interest, in any case, since I'm coming at the same question from another direction.
    I'm gonna guess you could end up in the high 3s AWHP fairly easily, if you have access to a decent tuner.
    You've got the AEM, and I'm looking solely at an FPR for tuning, initially, but you've already got bigger injectors, etc.
    Keyan made 420 I think. You'll have to change out your MAF with MAFT or similar to get those kind of #'s. I plan on using a set of DSM 13G's on one of my cars after it get's paint. I will be looking for around 350 on a pump gas tune. At least that's what I expect to make adding them to a BPU car.
    Most powerful 13T car in the world @501awhp, PTE 780CC injectors, AFPR, E85, Greddy Profec B, 3.5" Granatelli MAF, MAFT, SS Headers and O2 housings front, 3SX downpipe, CRX racing FMIC, Dejon intake pipes, Ground Controls, Maximal adjustable rear control arms, Maximal TC Brace, Poly front and rear mounts, Vacuum Reduction, EGR block off plate, Hot Wired Walbro 255 and inline Walbro 255, Southbend stage 3 clutch, Slotted and vented rotors, SAFCII, Turbo XS BOV, 3SX FP hotwire, Seatle Short Shifter, Jackhammer timing gears: Best 1/4 mile 12.33 at 114.9 mph 1.79 60ft.
    Yes.
    Injectors are stock
    Injectors are stock
    I thought Hennessey's stage 5 build had 450s or something?
    Quote Originally Posted by vr3.9 View Post
    Sounds right.
    I'm hoping to push 300 without too much futzing around; MBC, maybe.
    I did 421 with exhaust, intercoolers, 2" charge pipes, 550cc, 3.5" MAF + MAFT at ~17psi tuned with SAFC. High 3xx power would be easy with a good tune and a healthy motor. And my EBC keeps my wastegates shut as late as possible allowing for 375awtq @ ~2900rpm. Which is, honestly, scary as shit for anyone I take for a ride LOL
    I believe 440 injectors are the best match for 13g's. Thats just what im told. 550's for 15g's.
    Stage 5 was just the turbos, VPROM & injectors wasn't till Stage 7.
    Quote Originally Posted by Drummer View Post
    the timing from the 550s are never a bad thing and will make more power
