For anyone interested. I purchased the Energy suspension sway bar bushings (23 mm front and 22 mm rear for TT Models) and they can be used on this car.
The brackets they come with are strait where our front ones have an angle on the top mounting point of the bracket. You will need to do a bit of bending but they will fit in there (barely).
New bushing next to old ones:
Installed on the car:
You may be able to do this with just the wheel off the car however I was replacing bushings and ball joint on the lower trailing/control arm so that was off the car as well (including the sub-frame).
The rears I have not installed yet but they are mounted on a flat surface so I so no potential problems.
Part numbers:
Front - 9.5159
Rear - 9.5158
I ordered these from oriely's auto parts but they also have other vendors. They are about $20 for each set (2 bushings per set). Might have a little different part name than that in the store but they are readily available.
