Results 1 to 10 of 13
Thread: My brothers 93 RT/TT wont start
    Forum User Not Verified Feedback Score 0 Miguel92.3000GT's Avatar
    May 2011
    Hey guys my brother 93 RT/TT wont start. We replaced fuel pump and both crank sensors. The car will turn over all day but it just wont start. Any ideas what this might be.
    supporter
    Feedback Score 14 (100%) stealthee's Avatar
    You have to do some proper diagnostics before we can even begin to help.
    Is there spark? Is there fuel getting to the injectors? Is it in time? Have you ever checked the capacitors in the ECU?
    May 2011
    The answers to all your questions is yes except for the capacitors. What are they and how do you check them?
    Real drivers don't use speed limits verified Feedback Score 2 (100%) Woz's Avatar
    Buffalo, New York
    if the caps are blown you wont get spark
    Buffalo, New York
    and if you have both spark and fuel, then id check timing
    May 2011
    how do i check the capacitors and where are they located
    Prince George
    They're under the dash, take off the two inner kick panels on the center console and you'll see a grey or gold box with three yellow plugs going into it. Pull that box out and pop it open you'll know right away which capacitors we're speaking of. Check to make sure all the timing marks are lined up perfectly. I also wouldn't hurt to test your CAS'.
    Photobucket
    Buffalo, New York
    even if you just smell down there you can tell, it will have a strong odor of something electrical burned
    Jun 2011
    Not trying to be mean but... with the very limited experience you guys seem to have you might want to bite the bullet and see a mechanic...
    May 2011
    No mechanic needed, checked the caps and they are good turns out the CAS were bad. I replaced them myself and now this baby is roaring.
