I'm having some issues with high idle. I replaced the tb shaft seals to fix a large boost leak, but that didn't fix the idle. I included a list of things I have noticed while trying to troubleshoot this. I'm still learning how to work on this car so i'm not sure if all of this is relevant.
Can someone please point me in the right direction for troubleshooting this?
Issues:
- Idle sometimes stays up at 2000 RPM for 3-4 seconds when I stop at a stoplight. It will usually drop in steps somewhere in this range- 1500 rpm, 1200 rpm, then sometimes down to around 900 rpm.
- Turning the steering wheel all they way in either direction does not raise the idle.
- Biss screw all the way in, car still idles around 900rpm
- AC on drops the idle from 1200 to 900
- heater drops it more to 680-700 RPM.
- Turning off the climate control unit makes the idle go back to 1200 RPM.
- I had a short in a wire going to the ac control unit (black box under digital climate control unit) - not sure if it's related.
- The screen for the digital climate control unit sometimes does not light up.
- I hooked up a data logger and noticed that the AC clutch is always off and the AC switch is always on. Also, the Power steering always says Not Active.
- I also found this on the firewall. It's melted to where you can see some red inside the wire. Not sure what this is.
