all you all dissapoint me.
http://www.explorerforum.com/forums/...ad.php?t=18595
steve
97 VR4 12.41 on stock turbos
91 MR2 13.80 at stock boost
91 stealth TT with a couple bolt ons
and a laundry list of others....
Never listen to a significant other that suggests using conditionor as a lubricant when doing the deed in the shower, or anywhere else for that matter.
Filling up your gas tank, then riding by the next day to see the price has been lowered
Yes, I am cheap/broke
Even worse, forgetting to fill up on your normal day, then when you go to fill up the next day gas is up 10 cents for no reason.
^that always friggin' happens to me.
Driving to work and getting run off the road by an 18 wheeler crossing the yellow center....causing you to go off road and bust a front tire. Fucker.
Definitely sucks. I had a similar situation a few months back. I live on a country road that is just wide enough for two vehicles. Well a guy in a dually decided he though he onwed the road and was probably doing 50 on a 25 mph road at that. I had to swerve to avoid his rear fenders taking me out and ended up hitting a ditch with the rear wheel which broke the wheel bearing.
