1995 $ $8000
This car should put down an easy 500 AWHP on c16 and more boost. Feels really good on 14psi right now.
62,000 Miles
Mods:
sparco seats
UR crank pulley
Blitz DS Boost Controller
Magnecor spark plug wires (ill have to double check brand)
ATR Dual Exhaust
Component speakers (can't remember the brand but its high end and I added a Rockford Fosgate amp to power them)
Homemade FMIC 2"->3" (3rd revision looks good and hides BOV under fuse box)
Dejon Intake Pipes
19T turbos with HL wheels. (exhaust housings were ported an polished by Jonvr4; exhaust side ceramic coated silver)
Ported and Polished OEM headers (ceramic coated silver)
Greddy Type-R BOV
Emanage Blue
GTC Tech Intake Manifold
Q45 Throttle Body
Fuel Rail Loop
Snow Performance Methanol Kit (mounted but not in action because I don't care for disposable power)
AEM FPR
JackHammers Dual Fuel Pump Assembly
-6 AN Fuel Lines
Red Vacuum hoses and Couplers
RPS Max Pressure Plate with HPF Bronze Disk
99' Lifters
Polished Valve Cover
LT1 MAF w MAFT Pro
560cc Injectors
5spd Transmission
Nelson's TC Bracket
OBDI ECU (Still have the cali spec hybrid ecu if you want it)
AEM Wideband
flexalite fans
intrax lowering springs
UR lightweight flywheel
CIANCI pillars
Pictures:
Video:
