Results 1 to 10 of 18
Thread: AWD caliper bolt thread
    anybody know the thread for the caliper bolts? need to buy a tap and fix the threads on the knuckle - I think someone crossthreaded the shit out of the caliper bolts in the past.
    Feedback Score 6 (100%)
    12mm by 1.25 for fronts iirc
    Sent from my DROIDX using Tapatalk
    Rancho Cucamonga, CA
    Do you still need this? I have one front caliper apart and can check the bolt with the tap set. You're interested in the threads for the four bolts that hold the two sections together, correct, not the mounting bolts that hold it in place on the rotor? Might I add...gah that sucks
    Yeah, it struck me as odd that when I took out the bolts, two of them had different head sizes. I just remembered now since I need to change my pads.
    Forum User Feedback Score 2 (100%) Maximal's Avatar
    Avoca, NY
    Subscribed and if anyone can give me the length it'd be helpful. I'm running the ones from my NA brakes still and I need to space the bolts with a washer since they appear to be a bit longer than the TT ones. Learned that the hard way when it dug into the rotor. I could just get ones a bit shorter but would like to go with the actual size they came with.
    Yeah I just ordered a set of bolts from 3SX but they don't list the thread. I'm not at my parents house often, so I need to have everything ready to go and can't waste time running back and forth from the hardware store.
    I found the 12mm by 1.25 to be impossible to find in a hard bolt at the hardware store. I had to get them from mitsu. I could barely find a tap locally.
    anybody know the difference between a "plug tap" and a "bottom tap"?
    http://www.amazon.com/dp/B002KJMVO2/...SIN=B002KJMVO2
    http://www.amazon.com/dp/B002KSQLOO/...SIN=B002KSQLOO
    edit: wikipedia pwns me
    it doesn't matter because it is a through hole.
    Feb 2011
    NE oHIo
    I think plug tap and bottom tap are the same. A through tap has more of a taper where the tap starts. The bottom tap has a short taper so you can have more fully formed threads in a blind hole.
    From having to find metric fasteners over the years I know there are stores that stock sizes but NOT in common thread pitches, especially in the larger sizes. Head sizes are wacky too.
    -SP
