Results 1 to 4 of 4
Thread: Just how even does the rear main seal need to be?
    Rancho Cucamonga, CA
    I just popped in my new rear main seal and it is pushed in approximately 3/32" from the outer lip on the housing. Is this far enough in or too far? That is where it was when I pulled it so I put it back to how it was
    That being said, there is a maximum of 1/32" fluctuation from the part on the seal that is most recessed to the location that is least recessed. I have read that getting it into the correct depth AND evenly is crucial, so is that minor change in depth going to be the difference between leak and no leak? I will pop it in a hair more if it is that important but I do not want to risk sinking it in too far or making the difference larger if that is acceptable enough for being "even."
    Alright, it's all lined up but is 3/32" a good depth for it from the outer lip on the housing?
    Forum User Feedback Score 3 (100%) toddrs93's Avatar
    Hagerstown,MD
    sounds fine, It just needs to be fully seated so you should be fine
  4. The Following User Says Thank You to toddrs93 For This Useful Post:
  5. #4
    Feb 2011
    NE oHIo
    Flat is what it has to be. Depth is only important if there is a groove around the sealing surface from a previous seal.
    -SP
