Results 1 to 5 of 5
Thread: Name that part!
    | @/|/| +|2()|/| verified
    December 2009
    Fox Cities, WI
    Name that part!
    I just would like to know what this rectangle thing is on the back of the passenger/temp radiator fan. I know its not temp sensor to actually turn the fan on because those are in the radiator...Its on a 91 VR4 if that matters...
    Also, I think we should turn this thread into a game . Or people just post up what they dont know...Thanks.
    TN
    The only thing I came up with in ASA is a resistor, radiator shroud blower (part #MB660754).. but I don't know if it is the same part you are talking about.
    Never finishes any verified
    Wake Forest, NC
    Pretty sure it's the resister the fan uses to kick from low to high speed. I think they placed it there as they have a tendency to get hot "hence the metal shield and directly in front of the airflow". Aftermarket fans are just on off so no need for the resistor.
    Check it out on Youtube!!
    Chrome ECU
    Hybrid 13g's
    EVO 560cc Injectors
    Spec Stage 3 clutch
    CX Racing Dual Core FMIC
    Megan SS Exhaust
    3rd Gen Lifters
    Maximal High flow converter
    Walbro FP & FuelLab FPR
    All -6an Lines
    AWS/ABS/Cruise Delete
    MP Rear Control Arms
    SS Brake Lines
    99 Front Conversion
    2nd gen Rear Bumper
    99 Combat Wing
    Complete interior LED Swap
    Skillard Fuel channel
    Oohnoo FPR Bracket
    More to Come......
    December 2009
    Fox Cities, WI
    If I have just the a/c fan, i shouldnt need it either than right
    Quote Originally Posted by dbest671 View Post
    you are 100% correct, when you google search that part # you come up with Google Image Result for http://www.3sx.com/store/catalog/USED1OFF/MB660754-1-thumb.jpg
    which shows the exact thing he's asking about.
    here is one on 3sx
    http://www.3sx.com/store/comersus_vi...dProduct=30006
    another (picture may be hard to understand, its sitting on top of a box.. not a ecu)
    http://www.dragtimes.com/parts/MITSU...453994926.html
    and here, its talked about on 3si (what happens when it fails)
    http://www.3si.org/forum/f1/radiator...g-help-510583/
  6. The Following User Says Thank You to Torch For This Useful Post:
