Cam gears with cas cog $30 each
Cam gears w/o cad cog $20 each
Na cam shafts with surface rust $50 each
Na valves $2 each will need ground
2g R\T bumper needs painted but in great structural condition $150
Stealth glass drivers headlight $95
Stealth turn signals $45 for the set, don't come with mounts.
Headlight bucket brackets for mounting stealth and 99 style headlights $40 these are new and made by me
Cam angle sensor $25
Na heads with nothing on them $50 each would be good to practice port and polishing and putting oversized valves. Both come with new VSS as an extra, one head already has the VSS on them and is assembled but the number one exhaust valves leak they just need to be ground and seated might be able to get away with lapping them. This head is $85 assembled.
Crank angle sensor$25
Throttle body needs idle screw $50
Working IAC (tested) $50
Working tps (tested) $50
IAC TPS and throttle body together $100
Pics will be added later
