Page 1 of 8 123 ... LastLast
Results 1 to 10 of 71
Thread: My setup, need suggestions and help .
    This is the HU.
    Infill G4 Double-DIN Car-PC Barebone (1.5Ghz, FM radio, Amplifier, GPS)
    I bought it because I just wanted to upgrade the OEM HU and for On board datalogging electric dash and all the other features that on board computer offers. Well ofcourse it didnt work like I planned the problem is this really annoying static noise problem and the only solution is to use the optical output.
    Im having a really hard time finding an EQ for this setup that would accept optical in (toslink) (2 channel PCM) .
    (fixed) no longer a problem i can use the rca outputs too
    And then there is the other issue I would like to have functional rear speakers too.
    ill mount the woofers in the rear 6x9 location
    And then there is the third problem if I use the optical output I need something to control the volume because the volume buttons on the Hu no longer works=(fixed) no longer a problem
    Monogamous Gigolo verified Feedback Score 8 (100%) 2fnloud's Avatar
    Quote Originally Posted by mb7050 View Post
    This is the HU.
    I bought it because I just wanted to upgrade the OEM HU and for On board datalogging electric dash and all the other features that on board computer offers. Well ofcourse it didnt work like I planned the problem is this really annoying static sound problem and the only solution is to use the optical output.
    And then there is the third problem if use the optical output I need something to control the volume because the volume buttons on the Hu no londer works
    OK with that added fact, I have nothing.
    Here is it installed, just needs a little refining/ aligning
    dust dust dust
    yep I also need a new cigarette lighter cover
    The HU got a touchscreen but I also bought this Logitech keyboard its wireless, two strong magnet holds it over the black suede piece I made for it, magnets are also there to guide it in the right position .
    I found this EQ
    Audison - Music Expression
    I knew about the bit one but didn't know about it having the digi input...reading manual now
    If you have a classy place to install the remote interface....THAT is your best option.
    it says It can reconstruct a stereo signal from a multi-channel signal. In addition it can reconstruct
    reconstruction a centre channel and subwoofer channels from a stereo input alone.
    I wonder if it can reconstruct a 4 channel signal from PCM 2channel opt input. so many output channels for me Im going to upgrade the speakers too but only using the OEM locations . Any recommendations for speakers, amps..
    might as well stick with Audison products...I like matching brands.
    Im trying to find the dimensions for the remote interface but with no luck
    on page 4 of the owners manual
    43.5 mm tall
    17mm thick (23mm thick accounting for dial on the unit)
    For the width I can only see the width of the bracket, if you assume that the remote width is the same it is 90mm. even if it is not it wouldn't be that much bigger than that.
    Hope that helps
  11. The Following User Says Thank You to 2fnloud For This Useful Post:
