Results 1 to 5 of 5
Thread: Side skirt
    Forum User supporter Feedback Score 1 (100%) Rocket's Avatar
    Side skirt
    By any chance does anyone have a small handful of extra umm body push pins that attach the side skirts? I had/have a driver's side fender issue that I pulled the fender to work with. In the process I found the previous owner had the fender/skirt off before. Several of the black pins are broken. When I replace the fender I need to replace the skirt as the screw mounting holes are all busted out and had larger washers holding it in place.
    If anyone happens to have some extra pins it would sure help me out. The car is finally running after 3 yrs of sitting, the fender isn't hitting the door anymore, but the driver's side looks like ass without a skirt. If it isn't one thing it is another. Things to put on the to do list after I finish classes next year.
    Thanks!
    Brandon
    Forum User Feedback Score 0 jbuhrman's Avatar
    Dec 2005
    Williamsport, PA
    Are they broken and still in the body or just not there?
    You could do like one guy did and epoxy a bunch of small magnets to the side skirt so that it hold on by itself.
    Just some idea's
    Now magnets would be interesting eh? I'll have to do a search for that. These are broken and falling apart where they attach at the side skirt. I have to deal with a couple of places on the skirt where the pins go that are broken but right now the pins are the hold up.
    Dec 2005
    Williamsport, PA
    Quote Originally Posted by Rocket View Post
    If its where they mount to the skirt but the pins are not them selves broke epoxy the pins on. There are 2 in the rear thst actualy mount with nuts
    I have one in the front and one in the rear that have a nut on them.. 1 broken shaft and several broken bases on the skirt side. I will epoxy them in place and go from there. Just to be straight too, do the push pins then deal with the bolts?
