Update: backstock has been sold. However, I can still get these brand new and in box for $400 + shipping. They just cleared SFI and will all carry a 6 month/ 5k warranty with reciept of having your flywheel machined or replaced. Each kit comes with a heavy duty pressure plate, MIBA 6 puck unsprung disc with racing designed center hub, standard TOB, and an alignment tool. The tested and verified holding capacity on these clutches is 750ft/lb at the flywheel. They will easily support power in the 450-600 AWD range. Breakin takes about 300 miles of banging thru the gears on a spirited drive.
They are hybrid of a Comp Stage IV (unsprung 6 puck disc model 0620) and an ACT MB2-HDR6 (6 puck unsprung). They are HD pressure plates with MIBA / FE / carbon ceramic 6 pucks w/re-inforced center hubs. Clutch specs and retail pricing of each respectable setup can be view'ed here: Mitsubishi 3000GT Clutch Kits at Custom Cars Central
$400 each (+) shipping. Each clutch will last about 20,000 miles with the power.
I can also include an AASCO OEM billet chromoly replacement flywheel weighing 14.8lbs. Flywheel is also SFI 1.1 certfied and are one piece (not a two piece with welded ring-gear). They are made out of 4140 forged chromoly steel (which means you will never have to turn the flywheel again), are cut from a solid piece of steel, and also have an integrated vein design to keep the clutch cool. They will accept any 3/S TT bolt on replacement pressure plate; OEM, Exedy, Spec, ACT, Carbonetic, Clutchmasters, RPS, and etc. I will not post pics on them as they are absolutely custom and don't want anyone to copy, however, I will guarantee fitment and very noticeable performance gains. I will let the chromoly flywheels go for $425 each.
Shhhh dont tell..
