i understand what my problem is. i also have a set of gauges. i have no leaks. im just trying to figure out what the expansion valve is
i found this, is this the right part
BRAND NEW AUTOMOTIVE A/C EXPANSION VALVE 10034 | eBay
yep, that's an expansion valve. If it fits are not you'll just have to trust the seller on that. To replace the expansion vavle you have to pull the evaporator.
Pull the glove box and under dash passanger side stuff. You have to take the hoses off the firewall side and I think theres a bolt too. It's not a horrible job. You will see the expansion valve mounted on the evaporator.
Most powerful 13T car in the world @501awhp, PTE 780CC injectors, AFPR, E85, Greddy Profec B, 3.5" Granatelli MAF, MAFT, SS Headers and O2 housings front, 3SX downpipe, CRX racing FMIC, Dejon intake pipes, Ground Controls, Maximal adjustable rear control arms, Maximal TC Brace, Poly front and rear mounts, Vacuum Reduction, EGR block off plate, Hot Wired Walbro 255 and inline Walbro 255, Southbend stage 3 clutch, Slotted and vented rotors, SAFCII, Turbo XS BOV, 3SX FP hotwire, Seatle Short Shifter, Jackhammer timing gears: Best 1/4 mile 12.33 at 114.9 mph 1.79 60ft.
ok thanks for verifying, i double checked with the seller an he said it fits. so i should leave the vacuum on the system for an hour, does it just hook the low pressure side an suck all the crap out or what?
ill look up more instructions on how to remove the expansion valve.
I hook it to both sides and pull vacuum. Doesn't really matter when pulling vacuum as long as you get all the air out.
well. i hate this ac system, i pulled a vacuum on it, instructions said to leave it vacuuming for 10 min, i did that. got it down to -40 psi. i put a can an a half in it an its at 0 psi according to a set of real ac gauges. but still no ac. im just checking to confirm if this sounds right. should i just keep adding freon??
btw, the expansion valve can eat my ass. i spent a total of 7 hours changing it. mr mich ultra was there to help though
-40 PSI is impossible. -14.7 PSI is the theoretical perfect vacuum at sea level, but you would never get there in reality.
If you put a can of refrigerant in your system and are still at 0PSI then you have a very bad leak somewhere.
Im sure he means inches of mercury. My pump pulls down to -30 inches or so. I pull for 45 minutes. Then I close the valves and leave for twenty minutes. If the vacuum holds I then consider the system leak free.
You sure that can us empty? 1 can doesn't provide much, if any cooling, but you should have 30 psi or more in the high side at least. Did the compressor kick in. If you need some help after hours shoot me a pm and ill give you my cell number.
I've worked on ac quite a bit.
Sent from my DROIDX using Tapatalk
alex, huge leak i found.
forestgump, i may take you up on your offer. you have helped me alot through out this fiasco.. as of right now. i guess when i changed the expansion valve i bent the tube that comes from the fire wall an it created a hole. so as soon as i put freon in it just blew right out lol. why am i having such a hard time with this damn ac. anyways i jb welded the shit out of the hole,i think it will hold.
when i pulled a vacuum the gauge read negative 40. im not sure if its psi or what to be honest with you.
im pull another vacuum an she how it goes this weekend.
its freakin hot out too
I'm afraid I'd get another valve or get the tube brazed at a welding shop. The a/c is under tremendous pressure and vibration, jb weld isn't going to hold IMHO.
im gonna try my luck because my first thought was just to get a used one. but in order to get that one pipe out you have to pull the dash an disassemble the entire ac system under there. jb weld is pretty strong it holds high pressure relief valves pretty good lol
