Anyone run into this problem? I installed new oil pressure gauge and the sender needed an adapter to fit the metric hole. Seemed ok and seems to work well. Got the axles back in tonight and found this issue.
The sender is touching the cv bootcan i switch it with the switch? If not it is use a angle adapter? Any ideas?
Tia
Sent from my Droid using Tapatalk
