This weekend I tore into my frontend; new balljoints, inner and outer tie rod ends, turned rotors, new pads from NAPA, new cv axles. The horrible brake shudder I used to have is completely gone. I have hubcentric rings on my wheels, and torqued them in a star pattern with a torque wrench.
Unplug the ABS system and see if that fixes the issues. A bad pump will cause shaking really bad! Pulled the ABS fuse and no more shaking!!!
Check it out on Youtube!! 93 Stealth TT - The Stealth Project Renegade Tech Works ECS Controller on Intrax Springs Chrome ECU Hybrid 13g's EVO 560cc Injectors Spec Stage 3 clutch Ninja Performance Output shaft & Input spool Ninja Performance Solid Tensioner & Gates racing T-Belt CX Racing Dual Core FMIC Megan SS Exhaust Fidanza Cam Gears and Clear Covers 3rd Gen Lifters HKS BOV K&N FIPK Maximal High flow converter Walbro FP & FuelLab FPR Maximal and Seattle Solid Mounts All -6an Lines Custom -6AN coolant neck lines AWS/ABS/Cruise Delete MP Rear Control Arms SS Brake Lines 99 Front Conversion 2nd gen Rear Bumper 99 Combat Wing Complete interior LED Swap Skillard Fuel channel Oohnoo FPR Bracket . . More to Come......
Lots of great ideas in here! Gotta figure out why mine shakes too.
Hub Centric rings fixed my shake at all speeds.
Forum Rules
