Well I’m not 10:1 anymore but it was before this build. With 10:1 you cant really run more than about 8psi without meth, race gas or e85 so stock turbos are fine. You do get more bang for your boost with 10:1 though. I didn’t have a LSD so trying to launch was a joke. I really didn’t have all that much traction in 3rd gear lol. If you do a TT conversion just make sure you research a lot and do it right. People cut corners and end up having troubles or screwing up their engine quite often. If you don’t have a back up car I wouldn’t do this because you’re making the car less reliable and you don’t want to drive it if there are bugs to be worked out. Also if you aren’t pretty mechanically inclined you might want to just save for a VR4 but if you are a TT FWD can be a lot of fun.
Thanks bro, yeah I finished about a week before BRG. Those damn LMI turbos blew pretty quickly though so I’ve been down over a month. I’m going to pick up some 19t’s or DR750’s here pretty soon. The LMI turbo blew so bad I lost about 3 quarts of oil from the dyno to about 2 blocks away. I hope they didn’t cause any other issues with my new engine.
