What is currently the best datalogger for hybrid ECU's? I want to get one but Im not sure which offers the best features or even which ones are still around. I know Mirage is gone.
I have Hand Held Halo and it does the job very well. It has quite a few open ports for extra inputs, and has a very active support forum if you ever have an issue.
Evo Scan.
Evo scan works very well with the hybrid ecu
Alright, so if I do Evo scan, all I need is this cable EvoScan 1.3D USB OBDII/MUTIII/SSMII Datalogging Cable and the software?
Can you verify that's the right cable so I can buy it?
I think that will work but you need to have Pin 1 grounded. You may need to swap pins 1 and 15 on the car side grey connector so the cable can control pin 1 (this functions like a controllable ground).
I had both the HHH and Mirage Hybrid logger. When I sold the 94, I included the Mirage cable. The HHH is very user friendly, which is why I opted to keep that one.
Can't speak for EvoScan.
+1 for HHH, very easy to arrange all the graphs to workout what's happening
1996 GTO, Owner since 2003.
I have a 94 Stealth TT, and ironically just tonight I busted out that cable, Evo Scan 2.6 (they have 2.8, but I just use 2.6 b/c that's the version I bought a while ago), and adjust a few settings on it like so:
EvoScan (2.6+ Basic Settings for a 94-95 3S)
and then you'll be good! I know the lack of "finite" information stinks for 94-95 3s.Also, I'm running this on a Windows 7 x64 Laptop!
