Results 1 to 10 of 10
Thread: Input Shaft Bearing Replacement
    Never finishes any verified
    Wake Forest, NC
    Question Input Shaft Bearing Replacement
    Thanks to Hans and Emilie with GZP I was finally able to get a new input shaft bearing to fix that damn trans rattle that is driving me nuts. Thanks Again!!!
    I have never opened a trans up but was told there is not much to swapping out the input shaft bearing. Anything I should look out for or anything special I need to do?
    Do I need a press to get the bearing in and out or is this something a rubber mallet will take care of . there is a machine shop down the road that does this type of stuff but if I can manage it with normal hand tools I would rather save the cost.
    Any tips or tricks are appreciated.
    Check it out on Youtube!!
    Chrome ECU
    Hybrid 13g's
    EVO 560cc Injectors
    Spec Stage 3 clutch
    CX Racing Dual Core FMIC
    Megan SS Exhaust
    3rd Gen Lifters
    Maximal High flow converter
    Walbro FP & FuelLab FPR
    All -6an Lines
    AWS/ABS/Cruise Delete
    MP Rear Control Arms
    SS Brake Lines
    99 Front Conversion
    2nd gen Rear Bumper
    99 Combat Wing
    Complete interior LED Swap
    Skillard Fuel channel
    Oohnoo FPR Bracket
    More to Come......
    You should be able to tap it in since a c clip holds it in place. Just pull the shifter shaft out of the trans and unbolt the bell housing. When reinstalling the shifter shaft, put some grease on the spring to keep it from falling off the shaft.
    Wake Forest, NC
    Shifter in neutral correct? Then just unbolt and pull out?
    I don't have to worry about anything inside the trans falling out when I separate the bell housing right?
    I have the Trans Service Manual but the details are not the best for each step.
    3S Image Gallery - Manuals/3S_AWD_trans_service_manua
    Lay the trans so you are pulling the shaft out sideways and not vertical so the spring on the bottom of the shaft doesn't fall off. Keep the trans in neutral. There is also a 13mm guide bolt that should be backed out before reinstalling the shifter.
    Nothing will fall out when pulling off the bell housing except for maybe the front diff. But you can figure out how to put that back in lol
    Wake Forest, NC
    I hope I can figure it out... LOL
    Had a bad experience with a 3s ATX. Had to replace the valve body on the trans. unbolted it and all the damn valve check balls fell out . I spent weeks trying to figure out where those damn check balls went. Got it back together to find out it was the pump that was bad... I swore off ATX trans in a 3s ever since...LOL
    Forum User Not Verified Feedback Score 2 (100%) RealMcCoy's Avatar
    Medford OR
    I'd recommend a press personally... I used to knock them in with a bushing driver and hammer until one day I screwed myself and broke one that I didn't have a replacement for. The shock of driving it in damaged the plastic cage holding the rollers. I don't take the risk anymore.
    Only fuck with the 10mm bolts on a valve body. The smaller ones hold it all together lol. This job is much less complicated.
    Medford OR
    I spent many years as an auto trans builder, so I can easily visualize what you did... You'll have to forgive me for laughing, I can just imagine the Oh F---! that that produced...
    Wake Forest, NC
    I won't be banging it in with the plastic cage. I'll make a shaft to slide over it out of pipe or something so I can bang it in only on the metal part. Basically the same tool that they would use to press it it.
    Yeah, wish I knew that back then...LMAO
    Back then I just dove into everything without researching first. I broke more than I fixed. I laugh myself know when looking back at it!
    Medford OR
    That was primarily what I was doing... The inertia of the rollers broke the plastic. Until it happend to me, I never even considered the possibility.
