Results 1 to 10 of 10
Thread: Name that engine gasket/seal!
    So, we're gonna play a game called "Name that Engine GASKET/SEAL!" basically I bought a reseal kit and have some that I don't know where they go.. so I gotta get em figured out so I can install them!
    This is the easiest way I figured to do it.. ( I know some of em, I think.. so I'll post what I think, if I am wrong correct me )
    1. Water housing 1
    2. Throttle body gasket (this is that fiber stuff instead of metal however)
    3. Thermostat
    4. ?
    5. ?
    6. ?
    7. Water housing 2
    8. ?
    9. EGR seal (also fiber instead of metal?)
    10. ?
    11. ?
    12. ?
    13. Oil pump seal
    14. ?
    15. Water pump seal
    I also have 4 tiny rubber O rings..
    | @/|/| +|2()|/| verified
    December 2009
    Fox Cities, WI
    1 and 7 (if they are the same size) are for the thermostat housing, either side that connects to the heads.
    4 is egr. 5 or 9, which ever is thicker is egr.
    Then the paper one (i believe is 9) oil pick up tube.
    11 is between the oil pump and oil filter housing.
    14 is the top of the rear main seal. I think the manual calls for RTV though..
    The cheap set from 3sx? Ive got the same lol. I kind of wish I would have gotten better gaskets but its too late now
    Canaan NH
    1 and 7, water housing, near coils, 3 is thermos stat,4 might be egr, 5 is egr pipe,13 is oil pump,15 is water pump.
    McPherson, Kansas, United States
    number 2 is throttle body!!! damn it. somebody got that one.... nm
    March 2007
    Muskogee, Oklahoma, United States
    Quote Originally Posted by Danube_3KGT View Post
    1. Water housing 1
    3. Thermostat
    4. ?
    5. ? (Oil pick-up)
    6. ? (Looks like an exhaust pipe gasket, should be two and metal)
    7. Water housing 2
    8. ?
    10. ?
    11. ? (Oil filter housing)
    12. ? (Water housing - the other side)
    13. Oil pump seal
    14. ? (front seal housing - But I don't see the front main seal)
    15. Water pump seal
    I also have 4 tiny rubber O rings.. (probably for your fuel rails)
    They usually send out a generic kit, so some may NOT be for your car.
    randy! help! I just had a uh oh happen.. a bad one.. and thanks for filling me in..6 isnt the exhaust ones though, i have those, both of em..
    Forum User supporter
    Oct 2010
    Rosemead,Ca
    1. Water housing 1
    3.
    4.egr
    5.egr pipe
    6. Thermostat
    7. Water housing 2
    8. Block off for water neck on driver side
    10. ?
    11. Oil filter housing
    12. ?
    13. Oil pump seal
    14. ?
    15. Water pump
    explain 8 please? is it a metal plate that blocks the hole?
    December 2009
    Fox Cities, WI
    For the rear main, you would have received only the rod seal. (O-ringish thing)...Then you re-use your old rear main bracket and pull out the old seal. That seal pictured up there is for the top part of the bracket.
    anyone else?
