Page 318 of 355 FirstFirst ... 218268308316317318319320328 ... LastLast
Results 3,171 to 3,180 of 3547
  1. #3171
  2. #3172
    Jul 2013
    St. Louis
    Taken 2 days ago while it was actually semi-warm here in St. Louis
  3. #3173
    Those curves . . .
  4. #3174
    Man vs 3/S verified
    Kingston, WA
    Did you go with dr900's, Checkered? Stock rebuild?
    3SNG15 Best overall
    Runs 12's (12.98's!!!!!!)
    My Garage
  5. The Following User Says Thank You to R/T93 For This Useful Post:
  6. #3175
    No Show NG11 Not Verified
    Mesa, AZ
    Kind of potato pic, but there she sits.
    Your 1993 Mitsubishi 3000GT SL is one of 4310 that received VIN numbers. Based on the order of the serial numbers, your car was the 2685th out of the 4310 that were made that year.
  7. #3176
    image.jpgI've been doing a lot of research, including why exactly I had a turbo fail. Thanks for getting the ball rolling with blackstone labs, I have leaned a lot. I'll go into details later but the summary is- coolant in the oil is bad. The sample after the gasket change still showed some and the next, even less. Put that together with over spooling turbos and low oil pressure and damage is likely. I sent my locked up dr800 to Pure Turbos in CA to rebuild because they have the ability to balance the chra at speed, which is more precise than most.
    After talking to their tech for a while and giving him lots of info like engine displacement, boost psi, oil pressure and type, use of car, etc. I learned I have been over spinning these turbos a lot and way out of the efficient range. He measured the wheels and emailed me a DR800 compessor map. (Top of page)
  8. #3177
    The tech recomended Garrett GTX 2867R turbos for my application to last longer by staying in the efficient zone and spool faster (because billet wheel and ball bearing center section).
  9. #3178
    STL, MO
    More power!!!
    1991 Stealth RT/TT
  10. #3179
    Jun 2011
    Sweden, Gothenburg
    Quote Originally Posted by Checkered vr4 View Post
    Those curves . . .
    that sticker xD
  11. #3180
    coolant in oil is very bad... sucks that something silly like that is what killed the turbo sounds like it's leading to a great upgrade though!
