Page 298 of 355 FirstFirst ... 198248288296297298299300308348 ... LastLast
Results 2,971 to 2,980 of 3547
  1. #2971
    1993 rt/tt Not Verified
    wa state
    I was going to post, but thought needs its own thread
    agreed...cause if having 2 more stealths in my garage (and negotiating for a third) along with 3 engines, 2 transmissions, and enough parts to build a fourth is "bailing on the platform" then IPD can go suck on yet another lemon to help his overly cheery disposition
  2. #2972
    don't take it personally. it was intended as a joke.
  3. #2973
    Canaan NH
    New sneakers
  4. The Following User Says Thank You to CoreyB For This Useful Post:
  5. #2974
    STL, MO
    What did you do with the old shoes?
    1991 Stealth RT/TT
  6. #2975
    New sneakers
    Wingnut was toward the top of the stealths I would put up with list. Now that he has had premature platformulation, you now have replaced his sorry ass!
  7. #2976
    Canaan NH
    Boozer I tossed them. Some had weather cracks in them. I still have the Rays gram lights wheels but one is bad. If anyone wants them I will let them go cheap.
  8. #2977
    Twin Turbo verified
    Melbourne, Australia
    Quote Originally Posted by wingnut View Post
    Are the brakes on that stealth you are parting out 1st or 2nd gen?
    Sent from my GT-I9300 using Tapatalk
    Waiting install
    Build Thread
  9. #2978
    New sneakers
    What wheels are those? Thanks for helping me decide what color I want!
    Sent from my HTC One using Tapatalk
  10. #2979
    Rota P45R
  11. #2980
    Feb 2011
    Scottsbluff, NE
    You're going to want to get 18X9.5 +30mm offset. Hub bore 67.1mm if they still offer it, otherwise you'll want hubcentric rings to adapt from 73mm(most likely) to 67.1. The rings can be had on Ebay fairly cheap.
    Oh yeah, also with a 92 TT, you're either going to need to convert to 2G front brakes or get a 10mm spacer for the front. The brake conversion is the better route since it's a little safer and you won't have quite as much poke (even without spacers the front wheels will stick out slightly past the fender).
    1995 Dodge Stealth R/T Turbo
